2005 Highlander alarm/remote start wiring
Bob8139
Member - Posts: 7
Posted: June 16, 2005 at 10:26 PM / IP Logged
Does anyone have alarm and remote start wiring for a 2005 Toyota Highlander.Thank's Alot
thepencil
Gold - Posts: 1,526
Posted: June 17, 2005 at 10:19 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / HIGHLANDER / 2005 / Remote Start
12volts white (40A), yellow (30A)   +   ignition harness
Starter BLACK/ white   +   ignition harness
Second Starter black   +   ignition harness
Ignition gray   +   ignition harness
Second Ignition green   +   ignition harness
Third Ignition N/A
Accessory blue   +   ignition harness
Second Accessory N/A
Keysense green   -   ign harn or BECU, 2nd plg dwn, pin 2
Notes: Using the status output from the remote start to trigger this wire will disarm the alarm without unlocking the doors.
The BECU (Body ECU) is behind the glove box, it is the module to the right.
Power Lock see DirectFax document 1070
Notes: The driver side wires are at the driver door module in the door. They are: lock - green in pin 4, unlock - yellow in pin 14, and lock detection - brown in pin 16.
The passenger side wires are at the BECU behind the glove box, 2nd plug down from the top. They are: lock - purple in pin 8, unlock - lt. blue in pin 13, and lock detection - brown in pin 11.
Power Unlock see power lock notes
Lock Motor blue   5wi BECU, bottom plug, pin 1
Notes: The BECU (Body ECU) is behind the glove box, it is the module to the right.
Unlock Motor brown   5wi BECU, bottom plug, pin 2
Parking Lights+ white to brown   +   driver kick, 20 pin plug, pin 8
Parking Lights- purple   -   switch or BECU, 2nd plug dwn, pin 18
Hazards orange   -   turn signal flasher left of column
Turn Signal(L) red   +   turn signal flasher left of column
Turn Signal(R) blue   +   turn signal flasher left of column
Reverse Light RED / black to pink   +   driver kick, 14 pin plug, pin 10
Door Trigger see notes   -   BECU behind glovebox, module to R
Notes: The driver door trigger is black in the 3rd plug down, pin 11. The front passenger door is lt. blue in the bottom plug, pin 16. The rear door trigger wire is lt. green in the bottom plug, pin 15. Use all three wires and diode isolate each.
Dome Supervision green   -   ignition key cylinder illumination
Notes: Also found brown (-) at the BECU, bottom plug, pin 11.
Trunk/Hatch Pin green   -   BECU, 3rd plug down, pin 6
Hood Pin GREEN/ black to white   -   pin switch or Theft ECU, pin 34
Notes: The Theft Deterrent ECU is behind the glove box.
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black   ac   ECM, top plug, pin 5
Notes: The ECM (Engine Control Module) is behind the glove box, it is the module to the left.
The tach wire is also found at the data link connector, pin 9, under the driver side dash.
Wait to start N/A
Brake Wire black   +   brake pedal switch
Parking Brake black   -   parking brake switch
Horn Trigger pink   -   switch or BECU, bottom plug, pin 10
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Notes: Standard on the Limited models, and optional on all other models.
Be careful whose advice you buy, but be patient with those who supply it.2005 Highlander alarm/remote start wiring - Last Post -- posted image.
Bob8139
Member - Posts: 7
Posted: June 17, 2005 at 6:54 PM / IP Logged
Thank's alot for the help
thepencil
Gold - Posts: 1,526
Posted: June 20, 2005 at 10:07 AM / IP Logged
You are welcome.
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
