Stereo Short?
johnny_scout
Posted: June 17, 2005 at 4:51 PM / IP Logged
I just switched out my head unit with another one to check and see if it works b/c i was having a problem with it. I tried to run just two wires to it to power it up and see if it would work, but the Grond came into contact with either the constant 12v or the switched, and now i dont have power to the stereo and the Clock for some reason. So i have two questions, the first is obviously, is it a short and/or what can i do t ofix this, and two, is the clock hooked up on the same circuit as the radio? I checked the fuse also, and it is fine so I' m not suer what else to do/look for.
John
jugga-nemo
Copper - Posts: 81
Posted: June 17, 2005 at 4:59 PM / IP Logged
What kind of car and does the cig lighter work?
5.25" Components & 5x7 Coax Kappas w/Power Acoustik OV4-800
KAC 7252 powering 2 D3 8" Diamonds
KDC-MP728, KGC-4042A
johnny_scout
Posted: June 17, 2005 at 6:10 PM / IP Logged
It is a 1994 integra and the cig lighter doesnt work now, btu the light inside the ashtray still oes, so i dont know if its on a diff. circuit or not.
John
jugga-nemo
Copper - Posts: 81
Posted: June 17, 2005 at 6:24 PM / IP Logged
How did you test the fuse? I've had it happen where the fuse looks good, but in reality, it's blown. I recomend using a wire tester (doesn't have to be a muti-meter), ground one end, and there is a notch at both sides of the top of the fuse; test both sides. You should get reading from both sides; if not, the fuse is blown, which is what it sounds like to me. It (hopefully) didn't short as that is what the fuse is for (I've had this happen to friends before).
johnny_scout
Posted: June 19, 2005 at 7:30 PM / IP Logged
I've got a multi-meter, but should i check the fuse itself, or put it inside the box and test it there? I also tried swapping it out with another fuse to see if it would work then but it didnt either.
John
johnny_scout
Posted: June 24, 2005 at 7:33 PM / IP Logged
an update, my cig lighter DOES work, so I'm thinking that i might have fried the wire? any sugestions?
John
OhioMike1101
Silver - Posts: 343
Posted: June 24, 2005 at 7:48 PM / IP Logged
Many times there are more than 1 fuse for the stereo.  Does your dome light still work?
furflier
Copper - Posts: 236
Posted: June 24, 2005 at 8:06 PM / IP Logged
Do you have 12v at the wire harness? If not then you have a bad fuse, if you do then the hu is fried.
samroza
Member - Posts: 43
Posted: June 25, 2005 at 1:28 AM / IP Logged
I vote for looking for a second fuse. I know Chevies have 2 fuses on the same circuit in two different spots. If one blows, but the fuse checked looks good, you would think it was something more serious.
Sam Roza
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
