expander filler for inside box
turbopseidon
Member - Posts: 18
Posted: June 20, 2005 at 12:01 PM / IP Logged
where can I get this stuff I read about it and now I can't find it...I built the box and am going to glass it but I want something I can pour into the inside that will fill any holes to make it air tite...i read about an expander on here that would do the trick im sure any ideas?
tehgregzor
Posted: June 20, 2005 at 12:19 PM / IP Logged
if you put that kinda stuff inside your box, you're really gonna reduce your airspace. You should do it from the outside. And, freakin A, if you're gonna make a fiberglass box, you should *really be able to not have any holes like that. At least, not after 3~4 good layers.
turbopseidon
Member - Posts: 18
Posted: June 20, 2005 at 12:31 PM / IP Logged
im just stating from a stand point that I want a nice air tight box just being over cautious thanxs..
oonikfraleyoo
Gold - Posts: 1,069
Posted: June 20, 2005 at 1:18 PM / IP Logged
If you make a fiberglass box and it's not airtight, throw it away and have someone else do it for you.expander filler for inside box -- posted image.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
ajgonzales
Member - Posts: 20
Posted: June 20, 2005 at 2:33 PM / IP Logged
dump some resin inside of it and swirl it around to get into the corners and whatever
civicdetailer
Copper - Posts: 51
Posted: June 20, 2005 at 5:48 PM / IP Logged
i got mine from us composites.. noone local had it
Nitrous is like a hot girl with an STD. You know you want to hit it, but you are scared of the consequences.
Crispix396
Member - Posts: 26
Posted: July 01, 2005 at 2:10 PM / IP Logged
I made the bondo/fiberglass resin mix... about 50/50... poured it inside and swirled it around...  I had a good sized leak that i didnt see prior to and a lot poured out o the ground (oops)  but that worked pretty damn good for me.
nothing amazing yet, but its coming
phatx96xaccord
Copper - Posts: 118
Posted: July 02, 2005 at 12:17 AM / IP Logged
After u do what the others suggest, try getting some undercoating spray and spray the inside of the box, also the brand Plastikote, has a product called trunk spray, or something like that, its kinda like undercoating, looks like it would do a good job sealing and sound dampening.
would u like your chicken original or extra crispy?
elmaschingon_18
Member - Posts: 21
Posted: July 03, 2005 at 2:17 AM / IP Logged
Hey Turbo, the resin expander is called Areosil or cabasil I believe. I bought a 10 pound bag from an industrial business who imports it from Germany. It cost me 70 big ones! Then I come to find out from an internet install buddy from Louisana that you can use regular baby powder to do the trick.  You simply mix resin and this substance together until you get the desired texture (usually until it's pourable) and next, add your MEKP(hardner) to the batch then it's ready to be poured inside the box. Concenterate on the corners, and where fleece meets to MDF. I do half inch thickness and it works fine.
Hope that clears or helps you out!
sanding sucks!
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
