Windstar 2003
mikes581
Member - Posts: 7
Posted: November 23, 2002 at 8:23 PM / IP Logged
Remote starter.      Wiring diagram like 2002 or different???
egtalon93
Member - Posts: 22
Posted: November 24, 2002 at 8:19 AM / IP Logged
|              12V|lt GREEN/ purple, red|+  |ignition harness            |
|          STARTER|green               |+  |ignition harness            |
|         IGNITION|WHITE/ yellow        |+  |ignition harness            |
|  SECOND IGNITION|PURPLE / orange       |+  |ignition harness            |
|        ACCESSORY|BLACK/ green         |+  |ignition harness            |
| SECOND ACCESSORY|black               |+  |ignition harness            |
|       POWER LOCK|lt blue/orange      |-  |20 pin plug at FEM module *3|
|     POWER UNLOCK|lt GREEN/ YELLOW     |-  |20 pin plug at FEM module *3|
|       LOCK MOTOR|RED / orange          |   |26 pin plug at FEM module *3|
|     UNLOCK MOTOR|yellow              |   |26 pin plug at FEM module *3|
|    DISARM DEFEAT|lt blue             |   |passenger kick panel        |
| PARKING LIGHTS -|*1                  |   |headlight switch            |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|BROWN / pink *2       |-  |passenger D pillar          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|tied in with door   |   |                            |
|         HOOD PIN|PURPLE / orange       |-  |12 pin plug at FEM module *3|
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|lt. blue/black      |-  |26 pin plug at FEM module *3|
|       TACHOMETER|*4                  |   |ignition coil *4            |
|       BRAKE WIRE|RED / lt. green       |+  |brake pedal switch          |
|     HORN TRIGGER|ORANGE / red          |-  |12 pin plug at FEM module *3|
|           WIPERS|blu/orn & blk/pnk   |+  |wiper motor                 |
|  LF WINDOW UP/DN|blk/yel - orn/yel   |A  |4 pin plug at FEM module *3 |
|  RF WINDOW UP/DN|wht/yel - tan/blu   |A  |high in drivers kick panel  |
|  LR WINDOW UP/DN|brn/yel - brown     |A  |high in drivers kick panel  |
|  RR WINDOW UP/DN|yel/blu - yel/blk   |A  |high in drivers kick panel  |
|        RADIO 12V|lt. GREEN/ red       |   |at radio                    |
|     RADIO GROUND|black               |   |at radio                    |
|     RADIO SWITCH|pink                |   |at radio                    |
| RADIO ILLUMINATE|lt. blue/white      |   |at radio                    |
|       LF SPEAKER|orn/lt grn-lt blu/wh|   |at radio or speaker         |
|       RF SPEAKER|wht/lt grn - grn/orn|   |at radio or speaker         |
|       LR SPEAKER|tan/yel - gry/lt blu|   |at radio or speaker         |
|       RR SPEAKER|brn/pnk - orn/red   |   |at radio or speaker         |
Notes:
NOTE:  This vehicle is equipped with PATS (Passive Anti Theft System).  Use DEI module 555U to over-ride during remote start.
*1 When adding parking lights you must ground the BLACK/ green and interrupt the dk.blue/white and tan/white to avoid feedback to the headlights. See direct fax document #1072 for wiring diagram.
*2 A diode must be placed in-line on this wire to avoid falsing problems. Cut the wire and put the cathode side away from the dome light, then tie the door trigger input on the cathode side on the BROWN / pink.  On models with the puddle lamps on the doors, can also use ORANGE / white in a 20 pin plug at the FEM for door trigger. DO NOT USE THE ORANGE / WHITE FOR DOME LIGHT SUPERVISION.
*3 The FEM module is located under the drivers side of the dash on the firewall.
*4 There is a triple coil pack on the driver side of the engine. For tach use any of the following wires: pink/white, RED / lt blue, or blue/lt green.
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
