2000 civic keyless
Powermyster
Silver - Posts: 962
Posted: June 23, 2005 at 4:42 PM / IP Logged
just putting an alarm into a civic and souldn't find the keyless wires. it has honda keyless but i couldn't find the wires to tie the alarm in or the module anybody help me out on a UK Model
Powermyster
Silver - Posts: 962
Posted: June 23, 2005 at 5:37 PM / IP Logged
anybody just post some suggestions i thougth i had the right connector99% sure of it   but none of the wires test
bak0707
Member - Posts: 38
Posted: June 23, 2005 at 5:44 PM / IP Logged
do you already have a wiring diagram
Powermyster
Silver - Posts: 962
Posted: June 24, 2005 at 3:58 AM / IP Logged
yeah its not good for this car trust me
i need someone who has done a civic and there feedback. installer told me me today that he had to cut the wires to the motor. i thought that it was going to be a walk in the park
bak0707
Member - Posts: 38
Posted: June 24, 2005 at 6:20 PM / IP Logged
no you don.t have to cut the wires. i did my civic and i used the lock and unlock wires from the driver side kick panel. i don't remember the colors but i don't think there is a diffrence between uk and the us as far as the wire colors.
bak0707
Member - Posts: 38
Posted: June 24, 2005 at 6:21 PM / IP Logged
just use a meter and check the wires from the k/e module in the kick panel
Powermyster
Silver - Posts: 962
Posted: June 25, 2005 at 6:05 AM / IP Logged
its a weird car i thought that it would have been the same as US models.
I know i have the right connector because when i disconnect it. the locking no longer works. i gave every wire in teh block a negative feed and not even a budge..
i'm gonna take the door card off today. try see whats going on.
DMM didn't turn up much i tried that.
tryed to get eh indicators at the stalk but its no good. anyone know where i can locate the wires on the opposite side off the relay.
accord78
Copper - Posts: 97
Posted: June 26, 2005 at 8:25 AM / IP Logged
u can tied into the wire at the drivers kick panel or the door lock control module witch is inside the drivers door little blue box!!!
Powermyster
Silver - Posts: 962
Posted: June 26, 2005 at 12:35 PM / IP Logged
cheers. i'll post my findings, will try this car again during the week..
good to know where the module is .  i was planning to take the door card off next anyway
Powermyster
Silver - Posts: 962
Posted: June 28, 2005 at 9:46 AM / IP Logged
this guy said he'll pop over tonight.
so 'ill let you know what happens.
