2 re sx dual 2 ohm sub wiring
snyderman5
Member - Posts: 32
Posted: June 24, 2005 at 4:29 PM / IP Logged
I ordered my re sx's and they will be here soon 2 re sx dual 2 ohm sub wiring -- posted image.
they are dual 2 ohm subs and I have 2. Are my only options to run them in 1/2 ohm or 8 ohm. I have the brutus 2005d mono amp. How can I get the amp to see 1 ohm or at least a 2 ohm load? I have 2 speaker terms on the amp if that helps.
Francious70
Silver - Posts: 629
Posted: June 24, 2005 at 5:28 PM / IP Logged
Net load: 2 ohms
Paul
jettagli03
Copper - Posts: 311
Posted: June 25, 2005 at 11:37 AM / IP Logged
RE has wiring diagrams on their website - http://www.reaudio.com/html/wiring.htm
snyderman5
Member - Posts: 32
Posted: June 25, 2005 at 2:56 PM / IP Logged
ok they do have the wiring info on the website but I was asking for a different way to wire them then what was on the website.
stevdart
Platinum - Posts: 5,816
Posted: June 25, 2005 at 11:55 PM / IP Logged
Two DVC 2 ohm subs are wired just as Paul showed you in the diagram above, for a load of 2 ohms on the amp.  Rule:  if you don't find the wiring in a wiring diagram for the subs you have to work with, don't make up  your own way of wiring.  If it were possible, it would be shown.  Here are a couple of wiring wizards that make life easier:
Subwoofer wiring guide
Woofer wiring wizard
In cases where multiple subs are too many to be shown in a wiring guide, you can use series and parallel calculators such as the ones on this site:  https://www.the12volt.com/caraudio/boxcalcs.asp#par
Always calculate the voice coils first, then the subs.  For example, if you hear "series/parallel", that's referring to DVC subs with coils in series and subs in parallel.  The diagram above is an example.
