1994 Jeep Cherokee Remote Start
83Rangerman
Posted: June 26, 2005 at 11:39 PM / IP Logged
Hi there,
I've got a '94 Jeep Cherokee 4.0L Auto that has had a Magnum Security remote start installed. The keyless entry operates the power locks, but the engine only cranks and will not start. Has anyone got remote start wiring info for this vehicle, and does it have a factory security system that may not have been bypassed.
Thanks,
Dean.
Chad7n7
Silver - Posts: 408
Posted: July 01, 2005 at 9:11 PM / IP Logged
Here is the alarm diagram for your vehicle.
thepencil
Gold - Posts: 1,526
Posted: July 02, 2005 at 7:56 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - JEEP / CHEROKEE / 1994 / Remote Start
12volts red    +   ignition harness
Starter yellow    +   ignition harness
Second Starter
Ignition blue    +   ignition harness
Second Ignition
Third Ignition
Accessory purple    +   ignition harness
Second Accessory
Keysense
Power Lock ORANGE / purple    +   drivers kick panel
Power Unlock pink/purple    +   same
Lock Motor
Unlock Motor
Parking Lights+ blue/red      drivers kick panel
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger yellow    -   underdash light
Dome Supervision
Trunk/Hatch Pin common with doors
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm GREEN/ orange    -   drivers kick panel
Disarm No Unlock
Tachometer gray/blue   AC   PCM
Notes: Powertrain control module located on left inner fender behind headlight.
Wait to start
Brake Wire white    +   brake pedal switch
Parking Brake
Horn Trigger black    -   ribbon cable st. col.
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.1994 Jeep Cherokee Remote Start -- posted image.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
