Impala & Monte Carlo keyless upgrade?
shesaidshewas18
Copper - Posts: 96
Posted: June 28, 2005 at 12:55 AM / IP Logged
DEI recommends not to upgrade the keyless entry because the motor wires rest approx. 7v. What if you added a resistor inline and out to ground from the alarms motor wires? 1k resistors?
dare_ds69
Silver - Posts: 419
Posted: June 28, 2005 at 6:07 AM / IP Logged
you can try, but you can fried the BCM.
how own your mind, control your life.
MECP certified. always use a DMM
NowYaKnow
Gold - Posts: 1,217
Posted: June 28, 2005 at 6:13 AM / IP Logged
1k resistor won't cut it. Use relays and wire accordingly.
Pin 85: To motor wire in vehicle
Pin 86: To ground
Pin 30: To 12volt or ground depending what polarity inputs your module has.
Pin 87: To input on module
Also depending on the module you may need to connect 87a to ground for proper operation. Some modules want to see the motor wires rest at ground.
Mike
dare_ds69
Silver - Posts: 419
Posted: June 28, 2005 at 7:10 AM / IP Logged
if you are going to use 85 and 86 as nowyaknow said use a diode between 85 and 86 to avoid feed backs.
shesaidshewas18
Copper - Posts: 96
Posted: July 17, 2005 at 9:58 PM / IP Logged
Hmm... Diode, striped side by the 85 right?
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
