516u Voice Module Installation Guide
spider228
Member - Posts: 8
Posted: July 04, 2005 at 11:36 AM / IP Logged
i took my alarm out of my old car along with the voice module and cant get the module to work right.  can anyone send me the guide for the voice module.
CutDog504
Silver - Posts: 637
Posted: July 05, 2005 at 11:49 PM / IP Logged
I dont have an install guide, but I've installed quite a few of these. What problems are you having? Is it wiring, or the dipswitch settings? Also, I've seen the "speaker" (the part that looks like a siren) go bad on a few, so you may want to test it with an ordinary speaker to see if you are getting any output from the two brown "speaker" leads.
spider228
Member - Posts: 8
Posted: July 06, 2005 at 5:37 AM / IP Logged
im only getting the warn away. it wont say anything when i arm it or disarm it.
CutDog504
Silver - Posts: 637
Posted: July 08, 2005 at 1:09 AM / IP Logged
You have one of the dipswitches set wrong. Let me get back to you on this, I'm gonna try and find the correct order they need to be flipped to generate the armed/disarmed AND warn away messages.
spider228
Member - Posts: 8
Posted: July 08, 2005 at 4:06 PM / IP Logged
thanks in advance
CutDog504
Silver - Posts: 637
Posted: July 09, 2005 at 2:35 AM / IP Logged
Try changing the 4th dipswitch, see if that works.
spider228
Member - Posts: 8
Posted: July 09, 2005 at 5:05 PM / IP Logged
It says Viper Disarmed when i turn the key on and then Viper Armed when i turn the key off.  Do you know what wires go where.  Oh yeah it started sayin that when i fliped the 4th dipswitch.
CutDog504
Silver - Posts: 637
Posted: July 10, 2005 at 2:23 AM / IP Logged
Sounds like yer getting feed back thru the orange wire. You must also have a starter kill relay connected to the same orange wire coming from your alarm. All you have to do is diode isolate them and that should solve your problem. Just wire in two diodes like a "Y" to the orange wire coming from your alarm. Connect the sides with the stripe together and that side should be facing the alarm. Now connect the orange wire from the 516u to one of the diodes, and the starter kill relay to the other diode.
spider228
Member - Posts: 8
Posted: July 10, 2005 at 8:31 PM / IP Logged
i read my installation guide for the alarm and it said that i had to install a diode on the orange wire if i wanted the add an addition module.  I insalled one and it works great.  Thank you so much for the info.
CutDog504
Silver - Posts: 637
Posted: July 11, 2005 at 1:41 AM / IP Logged
Glad to lend a helping hand516u Voice Module Installation Guide - Last Post -- posted image.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
