2005 Mazda 6 Alarm/Remote Start Wiring
Welcome Guest :)
zfactor
Member -
Posted: July 12, 2005 at 1:10 PM / IP Logged
just need a wiring sheet for this car (alarm/remote start) preferably directechs but anything will help thanks
chungo
Copper -
Posted: July 12, 2005 at 5:09 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - MAZDA / 6 / 2005 / Remote Start [PRINT THIS PAGE] 12volts | black (40A), BLACK/ yel (30A) | + | ignition harness | Starter | BLACK/ blue | + | ignition harness | Second Starter | N/A | | | Ignition | blue | + | ignition harness | Second Ignition | N/A | | | Third Ignition | N/A | | | Accessory | BLACK/ red | + | ignition harness | Second Accessory | BLACK/ white | + | ignition harness | Keysense | WHITE/ blue | + | ignition harness | Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors. | Power Lock | lt. green | - | driver kick or door lock module | Notes: Lock is negative trigger thru a 1000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.The door lock control module is located above the passenger kick panel. | Power Unlock | same as power lock wire | | | Lock Motor | RED / blue | 5wi | driver kick or door lock module | Notes: The door lock control module is located above the passenger kick panel. | Unlock Motor | RED / green | 5wi | driver kick or door lock module | Notes: The door lock control module is located above the passenger kick panel. | Parking Lights+ | lt. GREEN/ black | + | driver kick, 14 pin plug | Parking Lights- | RED / white | - | headlight switch | Hazards | blue/orange | - | switch or door lock module | Notes: The door lock control module is located above the passenger kick panel. | Turn Signal(L) | WHITE/ black | + | turn signal switch | Turn Signal(R) | WHITE/ red | + | turn signal switch | Reverse Light | RED / yellow | + | driver kick, 14 pin plug | Door Trigger | GREEN/ orange | - | driver kick or door lock module | Notes: The door lock control module is located above the passenger kick panel. | Dome Supervision | yellow/black | - | driver kick or door lock module | Notes: The door lock control module is located above the passenger kick panel. | Trunk/Hatch Pin | brown | - | driver kick or door lock module | Notes: The door lock control module is located above the passenger kick panel. | Hood Pin | gray/red | - | pin switch or theft module | Notes: The theft-deterrent control module is located in the center console. | Trunk/Hatch Release | yellow | - | switch or door lock module | Notes: The door lock control module is located above the passenger kick panel. | Power Sliding Door | N/A | | | Factory Alarm Arm | blue | - | driver kick or door lock module | Notes: Arm is negative trigger thru a 1000 ohm resistor. Disarm is a straight negative trigger. MUST use relays.The door lock control module is located above the passenger kick panel. | Factory Alarm Disarm | same as factory alarm arm wire | | | Disarm No Unlock | use key sense wire | | | Tachometer | NOT blk/wht or grn/stripe | ac | any ignition coil or coil pack | Notes: On the 4 cyl models use the wire that is NOT BLACK/ white. On the 6 cyl models use the wire that is NOT GREEN/ stripe. | Wait to start | N/A | | | Brake Wire | GREEN/ YELLOW | + | brake pedal switch | Parking Brake | brown | - | parking brake switch | Horn Trigger | PURPLE / white | - | switch or door lock module | Notes: The door lock control module is located above the passenger kick panel. | Memory Seat 1 | N/A | | | Memory Seat 2 | N/A | | | Memory Seat 3 | N/A | | | Interface Module: | Category:Immobilizer Bypass | Required:Yes | Type:Transponder | Part #: 556UW | Alternate Part1 #: 555U | Notes: Standard on all models. | Interface Module: | Category:Door Lock Interface | Required:Yes | Type:Multiplex | Part #: 456LW | Notes: |
zfactor
Member -
Posted: July 12, 2005 at 11:39 PM / IP Logged
Monday, May 13, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
