2001 Kia Sportage alarm/remote start
Phenz
Copper - Posts: 48
Posted: July 19, 2005 at 2:37 PM / IP Logged
Hi guys. I have finished installing a dvd system (stereo/speakers/monitors), neons, and a couple of amps & subs in my 2001 kia sportage. Would anyone be able to assist me with installing a remote start/alarm system?
I currently have a factory installed alarm system which I wish to replace with an aftermarket alarm/remote start 2 way. I would like to know which alarm is best recommended, along with the wiring diagram for my car.
I could not find my car's diagram on this site, and would appreciate any/all help available!
I would not have been able to do any of the installs I have completed without the great advise and assitance offered through this site.
dare_ds69
Silver - Posts: 419
Posted: July 20, 2005 at 5:55 AM / IP Logged
use the Hornet 554R is a great combo unit.
12volts WHITE/ red   +  ignition harness
Notes: If equipped with a knee air-bag system, unbolt without disconnecting to access wiring.
Starter BLACK/ red   +  ignition harness
Second Starter
Ignition BLACK / YELLOW   +  ignition harness
Second Ignition BLACK/ white   +  ignition harness
Third Ignition
Accessory blue   +  ignition harness
Second Accessory
Keysense
Power Lock WHITE/ red   -  drivers door harness
Notes: Can also find a blue/black wire in a yellow connector behind the dash dimmer switch or in the door boot and wire as type *F*. This wire will not arm and disarm the factory alarm.
Power Unlock RED / green   -  drivers door harness
Lock Motor
Unlock Motor
Parking Lights+ blue / YELLOW    dash dimmer switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger YELLOW /GREEN   -  drivers kick panel
Dome Supervision same as door trigger
Trunk/Hatch Pin GREEN/ YELLOW   -  at rear dome light
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms on lock
Factory Alarm Disarm disarms on unlock
Disarm No Unlock lt. grn/blk or green   +  steering column
Notes: This is the key sense wire. The wire will meter 12v when the key is inserted in the ignition cylinder. Powering this wire as a third ignition during remote start will disarm the alarm without unlocking the doors.
Tachometer yellow/white    dianostic connector
Notes: The dianostic connector is located in the rear of the engine compartment on the drivers side.
Wait to start
Brake Wire orange   +  brake pedal switch
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
2001 Kia Sportage alarm/remote start -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
No
Type:
N/A
Part #: N/A
Notes:
how own your mind, control your life.
MECP certified. always use a DMM
Phenz
Copper - Posts: 48
Posted: July 21, 2005 at 3:46 PM / IP Logged
Thank you very much. I will try to work on it over the next 2 weeks, and let you know how it goes!
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
