2004 Ford Taurus Alarm/Remote Start Wiring
Mwsounds
Copper - Posts: 61
Posted: July 26, 2005 at 10:23 PM / IP Logged
OK, I have searched high and low for the wiring diagram for this vehicle. I just bought it on Saturday and need to get the wiring information so that I can put in my remote start alarm. Does anybody have it?
Thanks,
Mike Ward
Thanks,
Mike Ward
Get it done right the first time!
thepencil
Gold - Posts: 1,526
Posted: July 26, 2005 at 11:08 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / TAURUS / 2004 / Remote Start
12volts lt. GREEN/ purple (40A)   +   ignition harness
Starter RED / lt. blue   +   ignition harness
Second Starter N/A
Ignition RED / lt. green   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW   +   ignition harness
Second Accessory BLACK/ lt. green   +   ignition harness
Keysense BLACK/ pink   -   ign harn or GEM, 20 pin plug, pin 17
Notes: The GEM (Generic Electronic Module) is part of the SJB (Smart Junction Box) to the left of the steering column. It has three plugs on the bottom.
Power Lock pink / YELLOW   -   GEM, 26 pin plug, pin 18
Power Unlock pink/lt. green   -   GEM, 26 pin plug, pin 6
Lock Motor pink/black   5wi SJB, top plug, pin 3
Notes: The SJB (Smart Junction Box) is the fuse/relay box to the left of the steering column. It has three plugs to the left of the fuses.
Unlock Motor RED / white   5wi SJB, top plug, pin 2
Parking Lights+ brown   +   switch or SJB, bottom plug, pin 31
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) +   steering column
Turn Signal(R) wht/lt blu (F), org/lt blu (R) +   steering column
Reverse Light BLACK/ pink   +   kick panel, harness to rear
Door Trigger see notes   -   GEM, 26 pin plug
Notes: The LF door trigger is yellow/black in pin 5. The RF door trigger is gray/red in pin 19. The LR door trigger is lt. GREEN/ YELLOW in pin 20. The RR door trigger is pink/lt. blue in pin 7. Use all four wires and diode isolate each.
Dome Supervision BLACK/ lt. blue   +   SJB, top plug, pin 22
Trunk/Hatch Pin see notes   -   see notes
Notes: On the sedans use BLACK/ pink at the light in the trunk. On the wagons use WHITE/ purple at the GEM, 26 pin plug, pin 21.
Hood Pin tan/lt. green   -   GEM, 26 pin plug, pin 17
Trunk/Hatch Release purple / YELLOW   -   GEM, 26 pin plug, pin 3
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm pink/white   -   GEM, 26 pin plug, pin 4
Disarm No Unlock see factory alarm disarm
Tachometer NOT red   ac   ign coil/coil pack or fuel injector
Wait to start N/A
Brake Wire RED / lt. green   +   brake pedal switch
Parking Brake lt. green   -   switch or GEM, 26 pin plug, pin 1
Horn Trigger dk. blue   -   column or SJB, bottom plug, pin 1
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
SecuriLock
Part #: 556SW
Alternate Part1 #: 556UW
Alternate Part2 #: 555U
Notes:
Be careful whose advice you buy, but be patient with those who supply it.2004 Ford Taurus Alarm/Remote Start Wiring - Last Post -- posted image.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
