2005 GMC Envoy
cghendricks
Posted: August 03, 2005 at 6:47 AM / IP Logged
Anyone know where to find the wires that control the rear window roll up/down? Any info would be greatly appreciated...Thanks
c.h.
cghendricks
Posted: August 03, 2005 at 6:49 AM / IP Logged
Let me make this clearer...it is a 2005 GMC Envoy XUV
c.h.
mo12v
Posted: August 03, 2005 at 2:43 PM / IP Logged
This vehicle is DATA Link................
Reversal Rest At Ground Type Window Circuit
LF Window up/dn dk. blue - brown  A  driver door module in door
RF Window up/dn lt. blue - tan  A  front passenger door module in door
LR Window up/dn dk. blue - brown  A  LR window switch in door
RR Window up/dn dk. blue - brown  A  RR window switch in door
MO
NowYaKnow
Gold - Posts: 1,217
Posted: August 03, 2005 at 9:57 PM / IP Logged
Looking at the schematic looks like there is a switch for it in the overhead console that uses a resistored output to send a signal. Same goes for the rear key cylinder.
2005 GMC Envoy - Last Post -- posted image.
cghendricks
Posted: August 04, 2005 at 7:41 AM / IP Logged
Thanks for the info guys... I'll let you know how it turns out when I get the car back in the shop.
c.h.
cghendricks
Posted: August 09, 2005 at 6:38 AM / IP Logged
Thanks NowYaKnow! The diagram you posted was very helpful. I used the wires found at the overhead console for the rear window up/down. The only problem with controlling the window this way is that you have to power up the accessory circuit in the vehicle for it to work....no big deal for me as I had already installed a Viper 791xv so I just tapped into the ribbon cable accessory wire while grounding either of the window wires. Just be sure to diode isolate these circuits!
c.h.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
