04 Hyundai Tiburon Alarm/Remote Start Wiring
b jizzle 01
Posted: August 07, 2005 at 7:05 PM / IP Logged
I'm installing a alarm w/ remote start on a 04 hyundai tiburon w/o immobilizer and need the wiring diagram. Please assist if possible Thanx
Holla Back
swamprat323
Gold - Posts: 1,335
Posted: August 07, 2005 at 7:52 PM / IP Logged
2004 HYUNDAI TIBURON 2DR COUPE WITH 2.0L ENGINE AND 4-SPEAKER AUDIO SYSTEM
     Security
     WIRE          COLOR          POLARITY          LOCATION
     Battery          RED (2 WIRES)          (+)          IGNITION SWITCH HARNESS
               THERE ARE (3) RED WIRES, (2) ARE BATTERY AND (1) IS IGNITION YOU MUST TEST ALL THE RED WIRES
     Ignition 1          RED          (+)          IGNITION SWITCH HARNESS
     Starter 1          WHITE          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          YELLOW          (-)          8 PIN PLUG ON THE FRONT OF THE FUSE PANEL
               PIN #8
     Domelight Super          YELLOW/BLACK          (-)          AT BCM MODULE BEHIND FUSE PANEL BEHIND DRIVERS SIDE DASH
               PIN #8
     LF Latch          GRAY/BLACK          (-)          AT BCM MODULE BEHIND FUSE PANEL BEHIND DRIVERS SIDE DASH
               PIN #9
     RF Latch          GRAY          (-)          AT BCM MODULE BEHIND FUSE PANEL BEHIND DRIVERS SIDE DASH
               PIN #4
     Trunk Trigger          GREEN/ BLACK          (-)          8 PIN PLUG ON THE FRONT OF THE FUSE PANEL
               OR A 12 PIN PLUG AT THE BCM
     Hood Trigger          GREEN/ ORANGE          (-)          23 PIN PLUG AT THE BCM
     Alarm Disarm          RF TIVATED ONLY
     Alarm Arm          RF TIVATED ONLY
     Parking Lights          BLUE/ORANGE          (+)          AT THE STEERING COLUMN HARNESS
               OR (PINK/BLACK (L) GREEN/ ORANGE (R) AT A 22 PIN CONNECTOR AT THE BCM
     Low Crr Pk Lights          BLUE/ORANGE          (-)          HEADLIGHT SWITCH
     Convenience
     Headlights-Lo          BROWN          (-)          AT HEADLIGHT SWITCH
     Headlights-Hi          YELLOW/ORANGE          (+)          AT VEHICLE HEADLIGHT RELAY NEAR FUSE PANEL BEHIND DRIVERS SIDE DASH
     LF Pk Lt Bulb          BROWN / BLACK          (+)          AT FRONT LEFT PARKING LIGHT
     RF Pk Lt Bulb          PINK/BLACK          (+)          AT FRONT RIGHT PARKING LIGHT
     LR Pk Lt Bulb          BROWN / ORANGE          (+)          AT REAR LEFT PARKING LIGHT
     RR Pk Lt Bulb          GREEN/ ORANGE          (+)          AT REAR RIGHT PARKING LIGHT
     All Hazrd Lights          WHITE          (-)          AT HAZARD SWITCH
     LF Hazrd Bulb          WHITE          (+)          AT FRONT LEFT DIRECTIONAL LIGHT
     RF Hazrd Bulb          RED / ORANGE          (+)          AT FRONT RIGHT DIRECTIONAL LIGHT
     LR Hazrd Bulb          BLUE          (+)          AT REAR LEFT DIRECTIONAL LIGHT
     RR Hazrd Bulb          ORANGE          (+)          AT REAR RIGHT DIRECTIONAL LIGHT
     Wipers-Lo          GREEN          (+)          STEERING COLUMN
     Wipers-Hi          GRAY          (+)          STEERING COLUMN
     Parking Brake          BLUE/BLACK          (-)          IN HARNESS AT BASE OF PARKING BRAKE
     Trnk Release          BLUE          (+)          DR. DOOR JAM BOOT OR DRIVERS KICK PANEL)
     Remote Start
     Ignition 2          PINK          (+)          IGNITION SWITCH HARNESS
     Accessory 1          PINK          (+)          IGNITION SWITCH HARNESS
     Accessory 2          ORANGE          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          TRANSPONDER
     Anti-Theft Descript          RF ACTIVATED SYSTEM
     Key Sense          BLUE/ORANGE          (-)          8 PIN WHT PLUG ON THE IGNITION SWITCH
     Tachometer          GREEN OR (WHITE)          (AC)          2 PIN PLUG ON IGNITION COIL
               WHITE PIN 23 OF A PLUG IN THE PASSEGERS KICK
     Crankshaft Sensor          YELLOW          (-)          AT ECM MODULE IN PASSENGER KICKPANEL
               PIN #29
     Camshaft Sensor          BROWN          (-)          AT ECM MODULE IN PASSENGER KICKPANEL
               PIN #72
     Speed Sense          BROWN          (AC)          AT THE DATA LINK CONNECTOR UNDER DRIVERS DASH
               PIN #22
     Low Crr. Pk Lights          BLUE/ORANGE          (-)          HEADLIGHT SWITCH
     Brake Lights          WHITE          (+)          AT THE SWITCH ABOVE THE BRAKE
     Reverse Lights          GRAY          (-)          22 PIN PLUG AT THE BCM
     Horn          GREEN/ BLACK          (-)          4 PIN PLUG AT THE STEERING COLUMN HARNESS
     Modules
     WIRE          LOCATION
     Module 1          BCM - BODY CONTROL MODULE IS LOCATED UNDER THE DRIVERS SIDE DASH ATTACHED TO THE FUSE/RELAY BOX
     Doorlocks/Windows
     Power Unlock          YELLOW OR (BLUE)          (-)          DR. DOOR JAM BOOT OPEN WIRE TO UNLOCK
               STRAIGHT GROUND PULSE TO UNLOCK SEE DOOR LOCK DIAGRAM
     PowerLock          YELLOW OR (BLUE)          SEE NOTE          DR. DOOR JAM BOOT GROUND WIRE TO LOCK
               OPEN YELLOW WIRE WITH A RELAY TO LOCK SEE DOOR LOCK DIAGRAM
     Driver Mtr Unlock          GREEN/ BLACK          (REV)          22 PIN PLUG AT THE BCM
     Driver Mtr Lock          GREEN          (REV)          22 PIN PLUG AT THE BCM
     Pas Mtr Unlock          GREEN          (REV)          AT MOTOR IN DOOR
     Pas Mtr Lock          GREEN/ BLACK          (REV)          AT MOTOR IN DOOR
     LF Window Up          BROWN          (REV)          DRIVERS DOOR WINDOW SWITCH
     LF Window Dn          ORANGE          (REV)          DRIVERS DOOR WINDOW SWITCH
     RF Window Up          YELLOW          (REV)          DRIVERS KICK PANEL
     RF Window Dn          PINK          (REV)          DRIVERS KICK PANEL
     Sunroof Open          BLACK          (-)          AT OVERHEAD SUNROOF CONTROL SWITCH
               PIN #3 - THE WIRE COLOR MAY VARY.
     Sunroof Close          BLACK          (-)          AT OVERHEAD SUNROOF CONTROL SWITCH
               PIN #2 - THE WIRE COLOR MAY VARY.
dare_ds69
Silver - Posts: 419
Posted: August 08, 2005 at 6:20 AM / IP Logged
12volts red (x2)(common 30A)  +  ignition harness
Starter white  +  ignition harness
Second Starter N/A
Ignition red  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory pink  +  ignition harness
Second Accessory orange  +  ignition harness
Keysense blue/orange  -  ignition harness
Power Lock yellow or blue  F  BCM, 12 pin plug, pin 8 or 3
Notes: The yellow wire will test when moving the driver lock knob, the blue wire will test when moving the passenger lock knob.
The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash.
Power Unlock same as power lock wire
Lock Motor green  5wi BCM, 22 pin plug, pin 6
Notes: The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash.
Unlock Motor GREEN/ black  5wi BCM, 22 pin plug, pin 8
Parking Lights+ pink/black (L), GREEN/ org (R)  +  BCM, 22 pin plug, pins 10 and 5
Parking Lights- blue/orange  -  headlight switch
Hazards white  -  hazard switch
Turn Signal(L) RED / orange  +  BCM, 22 pin plug, pin 13
Turn Signal(R) orange  +  BCM, 22 pin plug, pin 17
Reverse Light gray  +  BCM, 22 pin plug, pin 2
Door Trigger yellow  -  BCM, 22 pin plug, pin 11
Dome Supervision yellow  -  BCM, 8 pin plug, pin 3
Trunk/Hatch Pin GREEN/ black  -  BCM, 12 pin plug, pin 6
Hood Pin GREEN/ orange  -  BCM, rear 20 pin plug, pin 9
Trunk/Hatch Release blue  +  driver kick, harness to rear
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock with ign, acc, and key sense
Tachometer white  ac  passenger kick, 23 pin plug, pin 4
Wait to start N/A
Brake Wire white  +  brake pedal switch
Parking Brake blue/black  -  driver kick, 15 pin plug, pin 2
Horn Trigger GREEN/ black  -  horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
04 Hyundai Tiburon Alarm/Remote Start Wiring - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
how own your mind, control your life.
MECP certified. always use a DMM
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
