remote start prob on 98 silverado
agg_07
Posted: August 12, 2005 at 12:52 PM / IP Logged
hi i need some help i installed a adiovox ax900 on a friends 98 silverado z71 and i got all the wiring done and just having probs with the remote start i  got the tach programmed or so i think i followed all the steps from the alarm manual the truck beeped and flashed the lights  i got the tach wire from the ignition coil pass side anyone help me on on this
agg_07
Posted: August 12, 2005 at 1:06 PM / IP Logged
the remote start does crank and the engine does run for about 1 or 2 sec. and the just shuts off
Satkunas
Copper - Posts: 97
Posted: August 12, 2005 at 2:03 PM / IP Logged
What did you use to bypass the Passlock II security? If you didn't bypass this or don't know what I am talking about you will need one of these.
agg_07
Posted: August 12, 2005 at 2:15 PM / IP Logged
nevermind i got it i hade to use some resistors thanks for the help if any hope this helps someone
