Use OnStar GPS antenna for N2?
BigBurbMan
Member - Posts: 20
Posted: August 22, 2005 at 12:20 PM / IP Logged
Since OnStar has GPS built in, is there a way to use that GPS antenna for an aftermarket NAV system like the N2?  Is there another NAV system that's a better choice?
CCroadshoptn
Copper - Posts: 67
Posted: August 22, 2005 at 4:33 PM / IP Logged
I dought the connections are the same. Also the type of signal that the OnStar recives(the gps signal may be incoded in the signal)  may not be the same as the gps signal that you need. Hope that helps.
Mecp Certified
Double check advice with your Meter.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
