what causes engine whine?
king244
Copper - Posts: 68
Posted: August 27, 2005 at 7:29 AM / IP Logged
what causes engine whine on some a.m. stations and to get rid of it...?
is it the ground method..?
truck is a 2004 f-350 head unit is eclipse avn-5495
skoldspuppy
Silver - Posts: 342
Posted: August 27, 2005 at 9:07 AM / IP Logged
Most of the time noise is caused by a bad ground, pull the HU out and make sure its grounded directly to the frame of the truck, also double check all your amps and there ground locations
Have a wire brush handy and dont be afraid to use it
--Skold
2004 Honda Civic Ex 4Dr
Kenwood DDX-7015/W Nav
4 Fosgate T152C
Hifonics Brutus BX1500D
RE XXX 12 in a 4 Cube Snail Shell
tcss
Silver - Posts: 1,623
Posted: August 27, 2005 at 12:51 PM / IP Logged
Actually AM noise is caused by one of two things. Your antenna might have a bad ground, but since your truck is new unless it has taken a hit I would doubt this. More likely, your ignition ( plugs and plug wires ) is overcoming weak AM stations thru your antenna. Resistor plugs and shielded plug wires should help. If the noise appears anywhere else besides AM Skold is right.
king244
Copper - Posts: 68
Posted: August 27, 2005 at 4:51 PM / IP Logged
no, it is just on am on 2 stations.....have to listen to those yankees games ya know   what causes engine whine? - Last Post -- posted image.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
