12'' Solobaric L7 Ported Box ?
Mvap
Member - Posts: 46
Posted: September 10, 2005 at 12:03 AM / IP Logged
I recently bought a Kicker 12 L7.
I want to build a ported box because I like deep bass for my 95 Jeep cherokee sport.
But there are a few issues!!  The Recommened Numbers for the Ported box are   2.5cu.FT+ port   /  2.5 x 13.25 port, 16.5" Long .
What do they mean by     2.5 x 13.25 port, 16.5" long.
I have  (2)   4 inch ports from another box I want to use, instead of  2.5'' ports ; Is that a good or bad Idea???
I NEED HELP SOMEBODY!!!!! ANYBODY!!!!!
I love Car Audio!
Bigsingh
Copper - Posts: 204
Posted: September 10, 2005 at 3:30 AM / IP Logged
no no no, see the dimensions that are given are for slot ports. these ports are made from the mdf used on the box, basically they are rectangularly shaped from the ends. so this one is a prism of 2.5*13.5. that is 16.5 long. just make a hole in your box and make a slot port shudnt take more than 15 minutes.
6* Rockford T2's
6* POWER AMPs
BLACK CORRADO
BAANNGGIINN
00navi
Member - Posts: 8
Posted: October 21, 2005 at 11:59 PM / IP Logged
Look at Kicker's website, they have a box building tips under the support section- tech support at www.kicker.com.
Alpine phantom Face CDA-7998
Alpine XMRadio,Alp. 12-disc ch
Kicker SX700.1, 2 SX1250.1 amps
2 kicker SS56.2 Components
1 12" SOLO-X 2-ohm dvc.
2 56.2sqFt boxes of hushmat
2 batt and H.O alt.....
honomichl
Copper - Posts: 128
Posted: November 17, 2005 at 8:31 PM / IP Logged
talked to a Kicker tech. today and they gave me the same measurments for ports. I have 2 kicker L7 and he said that i would be able to hit 142-152dbs. Here are the measurments they gave me 46"w,18"d,15"h  including porte measurments. Each sub is going to have own chamber. Tuned at 38 peak of 57 but diff. car equals diff peak
But back to the topic If you divide the width by 2 you would have your measurment for your sub hope that helps
you can't be ahead of the curb if you aren't LIVIN LOUD
hapache
Member - Posts: 12
Posted: November 28, 2005 at 1:05 PM / IP Logged
Would the box hit deeper and harder bass by getting rid of the center divider.
What amp are u powering those subs  honomichl???
I going with an Earthquake PHD2?
I'm on a mission to be as loud as i wanna be.
honomichl
Copper - Posts: 128
Posted: December 04, 2005 at 12:06 AM / IP Logged
No it would not hit harder. When i was talking to the kicker tech. He said that was a bad idea. Reason is lets say you blow out a sub without noticing. Now that other sub is in a way to big of a box. Which resulting in another blown up sub. My amp is a Kx1200.1. Don't know with the Earthquake PHD2 what are the specs.
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
