radio has power, but no speaker noise
kvnband
Member - Posts: 24
Posted: September 18, 2005 at 11:04 AM / IP Logged
OK, here is the situation.  One day, the stereo stopped putting out sound.  Went and bought a new stereo to put in, and the same thing is happening.  Power goes to stereo but speakers do nothing.  Tried new speaker in stock position with stock wiring...nothing.  Tried new speaker with new wire going straight from stereo to speaker...nothing.   When adjusting the volume, we hear a pop*pop*pop*pop*pop everytime the dial clicks, but that is the only sound coming out.  Any ideas what could be wrong?
Thanks,
Kevin
sedate
Silver - Posts: 1,173
Posted: September 18, 2005 at 12:08 PM / IP Logged
Shorted wire in the chassis somewhere?
Other than that, I got nuthin.
kvnband
Member - Posts: 24
Posted: September 18, 2005 at 12:12 PM / IP Logged
My dad is a master electrician, but this has got him stumped (it is in his truck, but I'm usually the stereo/alarm guy). We talked about how sometimes you can have a minor short that just takes away power from the line, so maybe the stereo is getting enough power to turn on, but not to power the speakers? He has seen it on ventilation systems before, but didn'tknow if that could happen in a vehicle. So that's all we've got right now too.
Kevin
godblessdremil
Silver - Posts: 273
Posted: September 18, 2005 at 12:22 PM / IP Logged
All i can really give you is some trouble shooting ideas
Ok take the radio out and hook it up to a 12volt (the red and yellow wires) then just hook up a speaker to test the channels. If they work on to phase 2.
Run new wiring to the speaker(Just start with one) if that one works do it to the rest.
If this doesn't work take a meter to the wiring, see if acc and constant are bolth getting 12 volts when the radio is on.
Other then that i have no idea.
DYohn
Moderator - Posts: 10,741
Posted: September 18, 2005 at 2:19 PM / IP Logged
Could be a bad ground.  Try directly grounding the HU to the chassis and not through the wiring harness.
evanc
Copper - Posts: 148
Posted: September 19, 2005 at 6:14 AM / IP Logged
Always factor in the possibilty of a blowm internal amplifier. You may just be that 1/1,000,000 that replaces a radio with a blown internal amp with another with the same problem. I'd go check out the new radio somewhere else to see if it works there.
sneakycyber
Silver - Posts: 413
Posted: September 19, 2005 at 12:54 PM / IP Logged
I am with dyohn on the ground. if there is an improper ground on the radio it will try and ground through whatever it can find. Most times through the speakers or through an rca.
speedwayaudio1
Silver - Posts: 879
Posted: September 19, 2005 at 1:48 PM / IP Logged
Dyohn is right, you could pull the hu out and bench test it too.
Big Dave
blackmica3
Copper - Posts: 128
Posted: September 19, 2005 at 3:08 PM / IP Logged
I have to agree on the ground. try regrounding the head unit. If that doesn't work, how are the speakers hooked up, hopefully both positive and negative are wired. I have seen situations where peeps have tried to ground the speakers to the chassis, NOT GOOD.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
