Installing Magnetic Reed Switch
torx
Member - Posts: 9
Posted: September 21, 2005 at 7:06 AM / IP Logged
First off, where can i buy the heavy duty ones (that arent prone to failure) other than from radioshack?
I wanna carry a magnet on my keychain, hold it or swipe it against a panel with the switch behind it and allow for the car to then be started..
Used as a kill switch of course.
Anyone done this? If so, how practical is it and would it be a wise investment?
Point me to some links or diagrams, or products
Thanks!!
kgerry
Platinum - Posts: 3,455
Posted: September 21, 2005 at 4:22 PM / IP Logged
back in the early-mid 80's we sold an alarm called Vandal Alert that operated this way.... you got a key fob with a magnet in it and hid the override switch behind a parking lamp lens.... the drag was ANYONE with a magnet could activate or deactivate your system... i would see the same problem with what you are trying to do.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
redpeppers
Silver - Posts: 483
Posted: September 21, 2005 at 11:09 PM / IP Logged
it is possiable....if the remote start u own had a negitive act. input wire...then u could put a mag. switch on the wndow or something and boom....
Where theres is a wire there's a way.
diggerdoo
Member - Posts: 14
Posted: September 22, 2005 at 7:44 PM / IP Logged
I don't think any magnetic switch would be a good idea on any car because the car is made up of metal, which attracts magnets. It could have a lot of negative effects on the sensor or switch.
floaterr
Silver - Posts: 383
Posted: September 25, 2005 at 11:06 PM / IP Logged
oohhh kkkkk....
Since your just driving a relay any should do, as long as their inside. I bought some cheapies once and installed them in my tool box in the back of my truck. First I sealed the holes (wire input) with silcone and they worked great. Stopped a turd from getting into it one time at a gas station too.
I imagine if a theif tried to start your car and it failed he'd think it was an alarm and start looking for other things (jumping at starter) then moving a magnet around the inside of the car. You'd just have to worry about passangers and mechanics, if they wanted the car that is.
ty
Copper - Posts: 137
Posted: September 27, 2005 at 2:25 PM / IP Logged
You can try these, http://www.autopreservers.com/8601.html not sure if they are heavy duty but they are made by dei so they should work fine.  I personally thought about doing this to but I also thought what if I forget the magnet?  That would suck, at least with a toggle switch you only have to remember to flip it.  The magnet idea is great though for the ultimate in hidden kill switches though, Good luck.
Cody
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
