--> | | Remote start / security / GPSWire/Function | CS-2016 FM | Vehicle Colour | Location/Description | Polarity |
| PASSIVE ANTI-THEFT | Blue/black (9-pin plug) | YES | PASSLOCK 2 | SEE NOTES | 12 VOLTS | Red x 2 (6-pin plug) | Red** | At module on steering column | + | IGNITION | Pink (6-pin plug) | Blue | Ignition switch harness | + | ACCESSORY | Gray (6-pin plug) | Brown | Ignition switch harness | + | STARTER | Brown (6-pin plug) | SEE NOTES*** | | | TACH SIGNAL | WHITE/ red (3-pin plug) | White | At ignition coil on top of engine | AC | LOCK | Green - / Blue + (3-pin plug) | White**** | In driver's kickpanel | - | UNLOCK | Blue - / Green + (3-pin plug) | White**** | In driver's kickpanel | - | DOORPIN | Green - / Violet + (5-pin plug) | Lt.geen/black***** | At driver's doorpin | - | TRUNK RELEASE | GREEN/ red - (9-pin plug) | BLACK/ white | At switch in dash | + | BRAKESWITCH | White (5-pin plug) | Blue | At switch above brake pedal | + | PARKLIGHTS | White +/- (3-pin plug) | Brown | At light switch harness or driver's kick | + | HAND BRAKE | | Lt. blue | Hand brake lever | - | HORN | BROWN / white (9-pin plug) | Black | In Airbag plug on top of steering column | - | CLUTCH SWITCH | | Yellow****** | At switch on clutch pedal bracket | + | VSS WIRE | | Yellow | At C2 connector on PCM******* | 8000ppm | DATABUS INTERFACE | | Pin-2(top row from left) | Diagnostic plug below dash | DATA | PASSLOCK DATA | | White | In 3 wire harness from ignition switch | DATA | PASSLOCK GROUND | | WHITE/ black | In 3 wire harness from ignition switch | - | Vehicle notes |
* This vehicle is equipped with a Passlock system that MAY NOT BE COMPATIBLE WITH SELF-LEARNING PASSLOCK MODULES currently available. A relay and a resistor should be used to bypass the system. Please refer to the appropriate security diagram.** The Orange power wire at the ignition switch is too small to be used for a remote starter. You can find a larger gauge Red wire at the module attached to the steering column.*** This vehicle has NO starter wire. The vehicle will start when the remote starter's accessory wire shut down for crank. Do not connect your remote starter's start output to anything.**** This is a 1-wire system. A ground will unlock the doors, a ground through 1.5K resistor will lock them. See the doorlock diagram for exact wiring instructions.***** The vehicle is equipped with a RAP system. You will need to pulse this wire after remote start shutdown, to turn off the radio.****** For manual transmission vehicles, connect your remote starter's start wire directly to this wire.******* The PCM is located under the hood on the left side of the engine compartment. On Automatics, the wire is found at pin-54. On manual transmission vehicles, it is found at pin-70. | |
| Note: The information on this sheet is provided to you on an as is basis with no representation or warranty of accuracy whatsoever. It is the sole responsibility of the installer to check and verify any circuit before connecting to it. Only a computer safe logic probe or digital multimeter should be used. Wiremagic.com Corporation and/or any associated or unassociated individual or corporation who furnishes this document and/or software assumes absolutely no liability or responsibility whatsoever pertaining to the accuracy or currency of the information supplied. The installation in each and every case is the sole responsibility of the installer performing the work and Wiremagic.com Corporation and/or any associated or unassociated individual or corporation assumes no liability or responsibility whatsoever resulting from any type of installation, whether performed properly, improperly, or in any other way. The information supplied is a guide only. |
| ©2004 Autoland All Rights Reserved |
| Print at: 9/26/2005 2:07:04 PM |
sneakycyber
Silver -
Joined: September 13, 2005 Location: United States Posted: September 26, 2005 at 1:17 PM / IP Logged
Whoooaaa That sounds like loads of fun... Good Luck
Sunday, May 19, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
