sealing subs down?
branvw
Copper - Posts: 90
Posted: September 27, 2005 at 1:34 PM / IP Logged
just a thought, today i have a sub box leaking alot of air from the factory gasket  mounted on the bottom of the sub, what do you guys use as a safe and secure air sealer for the sub to Glass???
Francious70
Silver - Posts: 629
Posted: September 27, 2005 at 2:46 PM / IP Logged
Weatherstripping
fr33w0rld
Copper - Posts: 73
Posted: September 27, 2005 at 4:38 PM / IP Logged
silicone
HU Alpine CDA-9855 Amp MA Audio 802sx 4,400 RMS 1 ohm Sub 18" MA Audio RMS 5,000 @ 1.5 ohm Ported Box Car 99 civic Si
kelrx8
Member - Posts: 10
Posted: September 27, 2005 at 7:09 PM / IP Logged
what he said weatherstrip works great and cheap
homedepot ,car auto parts stores are more like 8-10 bucks for a small roll.
mi_what
Copper - Posts: 208
Posted: September 27, 2005 at 9:52 PM / IP Logged
IF the subs are flush mounted you can try some sort heavy fabric. not fleece or anything like that, but, try something like felt, suede, maybe even try to find some sort of rubber insulation...spray or mat. that should seal the sub to the box but not loose the flushness.
abovestock
Copper - Posts: 247
Posted: September 28, 2005 at 1:07 AM / IP Logged
Silicone
+1
Why do you ask if I ate paint chips when I was younger?
realitycheck
Silver - Posts: 751
Posted: September 28, 2005 at 8:00 AM / IP Logged
Bran I had that problem in just a little area, like a 1"-1 1/2" long. So I took a piece of an old bicycle innertube and cut it to fit and then slid it underneath and screwed my subs back down and voila, no more leaky.
branvw
Copper - Posts: 90
Posted: September 28, 2005 at 8:58 AM / IP Logged
great thanks guys, i will test a few options out tonight and post the final product in the next few days
