VSS 2003 Silverado
bajaclawz71
Member - Posts: 45
Posted: October 01, 2005 at 10:24 PM / IP Logged
Where is the VSS wire located at the BCM on a 2003 Silverado?  I know that it is the green wire with a white tracer but what pin is it?
Thanks in advance,
Blake
Moderator - Posts: 12,488
Posted: October 02, 2005 at 10:23 AM / IP Logged
You can get it at the PCM (Powertrain Control Module) which is in the left front of the engine compartment to the left of the fan shroud. The VSS wire is in the green plug, pin 50 or you can access it at the instrument cluster in pin A4
airandsound
Copper - Posts: 69
Posted: November 03, 2005 at 1:14 PM / IP Logged
The cruise plug near the brake booster on the firewall
10 pin connector. POS K GREEN / WHITE wire
Sunday, November 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
