how to lay fg.mat over fleece
different_level
Posted: October 02, 2005 at 7:41 AM / IP Logged
I am working on my first box. Can I cut the mat into
square's and lay them down or should i use one whole sheet?
psalm 142-4,5&6
05honda
Copper - Posts: 100
Posted: October 02, 2005 at 10:00 AM / IP Logged
you most likely wont be able to use one whole sheet. The mat blends together easier if you tear it instead of cutting it....If you cut it, it will not lay down as flush....so i would tear it up into squares.....of maybe 7X7 depending on how big your box is....
youngone
Silver - Posts: 269
Posted: October 02, 2005 at 2:20 PM / IP Logged
i like to tear it and also tear some lines in the actuale peace of mat to get it to go around the curves better 7X7 sounds good to me
Want to know some good equipment- JL,Adire Audio,Mcintosh,Brax,Helix,Eclipse,JBL,RE,Dimoand Audio,Zapco, pritty much anything DYhon,Forbidden recommend
On the12volt you give some info and you get in
different_level
Posted: October 02, 2005 at 8:14 PM / IP Logged
Thanks for the adv. I also plan to glass my dash ,I ahve cut it up a little and moved the guages to the center, and going to add a screen to the passager side. Do I fallow the same steps in doing this as box or is there a different way.(any pics would help lots).how to lay fg.mat over fleece -- posted image.
psalm 142-4,5&6
jlord16
Silver - Posts: 322
Posted: October 03, 2005 at 1:58 AM / IP Logged
all glassing is prety much the same proceudre except the shape of the project ofcourse
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
mi_what
Copper - Posts: 208
Posted: October 03, 2005 at 3:42 PM / IP Logged
Just my experience...but when you choose to finally undertake the dash project, be sure to find a replacement dash just incase. Also, to help the glass and resin stick to the plastic scuff it up with 60 grit and drill lots of tiny hole into the dash before fiberglassing. Using a 1/16 or 3/32 bit normally does the trick for me.
different_level
Posted: October 03, 2005 at 9:47 PM / IP Logged
thanks , lots of help. I will post pic asap.  Any you can post will also help or sites.
psalm 142-4,5&6
different_level
Posted: October 03, 2005 at 9:51 PM / IP Logged
One more question , should I sand the surface before each layer of  mat or can I just lay on top and keep on going?
Thanks!
psalm 142-4,5&6
jlord16
Silver - Posts: 322
Posted: October 04, 2005 at 1:48 AM / IP Logged
Just lay the mat on 1 coat after the other.  U dont need to sand untill the final coat, unless you get some sharp points forming it the mat and you want to sand them smooth or there is a bump or airbubble you want to smooth out before the next coat
Clarion DB36MP
Respone 800w Mono
ALPINE MRP-F250
abovestock
Copper - Posts: 247
Posted: October 04, 2005 at 3:37 AM / IP Logged
Lay your torn mat down in one even layer. If you have a piece that is sticking up then sand it down as soon as you get a chance. Let each layer cure before adding another.
Why do you ask if I ate paint chips when I was younger?
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
