SWR-1042D t/s parameters
Alpine Guy
Platinum - Posts: 2,478
Posted: October 03, 2005 at 1:08 PM / IP Logged
Can someone please post or PM the specs for the alpine SWR-1042D sub, im going to build a ported box for my brother but lost my manuals.
tcss
Silver - Posts: 1,623
Posted: October 03, 2005 at 3:43 PM / IP Logged
External Dim. 12.5" X 14.5" X 17.5"
Gross internal volume 1.3 cu ft
Vent area 11 sq in
Vent length 22"
Vent displacement .237 cu ft
Net internal volume 1 cu ft
F3, ripple, Fb = 30hz, 3.5 db, 36hz
There is no such thing as free installation!
Alpine Guy
Posted: October 03, 2005 at 4:11 PM / IP Logged
Is that the alpine reccomended box?  I wana get the specs if possible so i can plug it into winisd pro and play around with it to suit it for his listening style.
Thanks tcss
tcss
Posted: October 03, 2005 at 4:24 PM / IP Logged
Taken directly from Alpine's dealer guide. What other specs do you need?
Alpine Guy
Posted: October 03, 2005 at 9:46 PM / IP Logged
if i could get stuff like the fs, qes, qms, qts, vas, re, le, bl, xmax, sd, spl,  and such if possible please.
tcss
Posted: October 04, 2005 at 11:38 AM / IP Logged
qes = .53
qms = 8.67
qts = .5
sd = 332
spl = 83 db  1w/1m
vas = .71 cu. ft.
This is all they list for what you asked for. Hope it helps.
Alpine Guy
Posted: October 04, 2005 at 12:10 PM / IP Logged
Perfect thanks, the alpine reccomended box was a little too spl peakish, extend the port to about 25" long and it should give me a nice all  around box.
Thanks for your help tcss
rustyspring03
Member - Posts: 20
Posted: October 04, 2005 at 3:54 PM / IP Logged
if its not too much trouble could you do the same for the swr-1242d ... i hate that alpine doesnt list this stuff on there site.. .i also lost the manual
Rusty Spring
98 s10 reg cab
Type R 12 Inverted between seats
Type R 6.5 for doors
Type S 5.25 on the dash
Alpine MRD-M605 mono
Alpine MRV-F345 4ch
tcss
Posted: October 04, 2005 at 4:13 PM / IP Logged
sealed box vol. = .7 to 1.0 cu. ft.
vas = 1.6 cu ft
qms = 7.89
qes = .5
qts = .47
sd = 480
spl = 85db 1W 1M
rustyspring03
Member - Posts: 20
Posted: October 04, 2005 at 11:18 PM / IP Logged
thanks i actually found that you can dl manuals off of crutchfield for free and they've got just about everything there
Rusty Spring
98 s10 reg cab
Alpine MRV-F345 4ch
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
