2006 Ram Diesel remote start
Nate_Dogg
Member - Posts: 35
Posted: October 20, 2005 at 1:49 PM / IP Logged
Has anyone put a remote start in one of these yet?
if you did..congrats!
but how do you turn off the ABS and Brake lamp in the
MIC after you put the key in the ignition?
re:2006 Ram 3500 deisel2006 Ram Diesel remote start -- posted image. 2006 Ram Diesel remote start -- posted image.
jaurora
Silver - Posts: 429
Posted: October 20, 2005 at 1:58 PM / IP Logged
Those stay on because of the Acc. wires. There may be more than one or the wrong one is connected. I noticed on my 2002 Ram that when I go to turn the key to the off position if I turn it slow there is a point to where the radio shuts off and the two lights come on ABS/Brake but the engine is still running. My remote starter doesent have a problem but the acc wires is just an asumption.
MECP certified (If it really means anything)
Jeremy
Nate_Dogg
Member - Posts: 35
Posted: October 20, 2005 at 2:01 PM / IP Logged
its a 2006 ,totally different beast.
jaurora
Silver - Posts: 429
Posted: October 20, 2005 at 2:08 PM / IP Logged
I know that. I have done my fare share of dodge rams and not once did I run into this issue. This is why I am saying to just check the acc wires. What I said above was just something that I noticed one day when I was leaving my truck.
Jeremy
Nate_Dogg
Member - Posts: 35
Posted: October 20, 2005 at 3:01 PM / IP Logged
Hmmmmm....nope, still only 1 MUX wire that comm.s with
ignintion-on.before and after remote start.
the MUX wire vt/brn...turns on everthing hvac,MIC,wipers
radio.when a resister is used.
Chrysler Tech.
Clarion dealer
Black Widow,Ungo alarms.
General electrical
extreme1
Silver - Posts: 1,070
Posted: October 21, 2005 at 2:42 PM / IP Logged
You can use a viper 456L self learning resister lock module to do the start/acc wires on that vehicle.
Otherwise 3 relays, one interupts the PURPLE / brown, one shows start resistance, the other shows acc resistance.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Nate_Dogg
Member - Posts: 35
Posted: October 21, 2005 at 7:41 PM / IP Logged
I seeeeee..... sounds interesting
thanks
Chrysler Tech.
Clarion dealer
General electrical
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
