Wireloom
mrcllusb
Copper - Posts: 489
Posted: October 24, 2005 at 7:26 AM / IP Logged
What's the best style wireloom to use for a stealth install??
"ole blake"
mrcllusb
Copper - Posts: 489
Posted: October 24, 2005 at 8:02 AM / IP Logged
Or should i use tape?? I know this can be a heated discussion,but everyones opinion is appreciated..
"ole blake"
Moderator - Posts: 12,488
Posted: October 24, 2005 at 8:44 AM / IP Logged
Depends on the vehicle. Some vehicles use plastic looming while others use electrical tape or even cloth ( hockey ) tape to cover the wires. In the engine I use slipt tube looming and under the dash I usually like to use eletrical tape and where applicable I use the looming as well.
mrcllusb
Copper - Posts: 489
Posted: October 24, 2005 at 8:47 AM / IP Logged
I have a dodge intrepid..
"ole blake"
mrcllusb
Copper - Posts: 489
Posted: October 24, 2005 at 8:52 AM / IP Logged
Also,what size, 1/4"?
"ole blake"
Posted: October 24, 2005 at 9:07 AM / IP Logged
Dodge likes to use the hockey tape under the dash and as for size, use whatever size you require for the wires that you want to cover up. If it's just a few 18 gauge wires, then using 1/4" is fine. Any more than 3 wires I would go to 1/2" or 3/8.
mrcllusb
Copper - Posts: 489
Posted: October 26, 2005 at 1:55 AM / IP Logged
Appreciate the help Velocity..I want my install to look as factory as possible...
"ole blake"
Teken
Gold - Posts: 1,492
Posted: October 26, 2005 at 6:02 PM / IP Logged
Mimic what the factory uses is close to stealth as you can get.
Always bare in mind that, pre-prep, is what the end result will look like.
If you simply tape and bundle the wires to OEM wires, anyone can tell.
If on the other hand, you retape / loom all wires in the same bundle, then that offers you the most OEM look.
Thought that clarification needed to be added.
Regards
EVIL Teken . . .
Knowledge is power. But only if you apply that knowledge in a positive way, which promotes positive results in others.
EVIL Teken . . .
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
