2003 Saturn L300 Alarm/Remote Start Wiring
sam1544
Posted: October 24, 2005 at 10:20 AM / IP Logged
I'm attempting to install a designtech model no.  23926 remote starter on a friend's 2003 Saturn L300.  I have taken the panel below the steering wheel off and the plastic around the steering wheel off.  On the driver's side of the steering wheel I found 2 plugs, a black one and a gray one.  I'm assuming that this is the ignition wire harness.  From the designtech website I got the wiring colors.  I can find the basic wires(ign1, ign2, start, acc).  My question is...... it says I need to connect the KEYSENSE wire to Ign 3 on the starter.  Is this wire in the harness itself?  I see a green wire and another wire on the passenger side of the steering wheel but am not sure what it is for.  Also, it says that this vehicle has PASSLOCK II security.  Are these wires in the main harness too?  Are they smaller than the others?  I have installed several remote starters before but not on anything this new.  Anybody know where I can get a wiring diagram for the ignition harness for this vehicle?    Thanks in advance.
thepencil
Gold - Posts: 1,526
Posted: October 25, 2005 at 9:41 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - SATURN / L-SERIES / 2003 / Remote Start
12volts red (x2) (30A each)   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition pink   +   ignition harness
Second Ignition dk. green   +   ignition harness
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory brown   +   ignition harness
Keysense lt. green   -   ignition harness
Notes: The lt. green key sense wire at the ignition harness must see a ground during remote start to keep the SERVICE light from coming on.
Power Lock RED / black   +   pin A8, 16 pin gray plug at BCM
Notes: The BCM (Body Control Module) is behind the glove box.
Power Unlock ORANGE / black   +   pin A7, 16 pin gray plug at BCM
Lock Motor gray   5wi pin B4, 30 pin plug, pass. fuse box
Unlock Motor tan   5wi pin A2, 30 pin plug, pass. fuse box
Parking Lights+ brown   +   pin B10, 24 pin gray plug at BCM
Parking Lights- lt. blue   -   pin B4, 16 pin gray plug at BCM
Hazards same as turn signal wires
Turn Signal(L) lt. blue   +   steering column
Turn Signal(R) dk. blue   +   steering column
Reverse Light lt. green   +   pin B4, 30 pin plug, driver fuse box
Door Trigger gray/black (D), BLACK/ white(P) -   24 pin gray plug at BCM
Notes: The driver door trigger is gray/black in pin B2, and the passenger door trigger is BLACK/ white in pin A12. Use both wires and diode isolate each.
Dome Supervision white   -   pin A1, pink plug at BCM
Trunk/Hatch Pin RED / black   -   pin B4, 24 pin gray plug at BCM
Hood Pin N/A
Trunk/Hatch Release BLACK/ white   +   pin B7, 24 pin gray plug at BCM
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT pink, brn/wht, or black   ac   ignition control module
Wait to start N/A
Brake Wire lt. blue   +   brake pedal switch
Parking Brake lt. blue   -   pin A2, 24 pin gray plug at BCM
Horn Trigger black   -   pin B2, pink plug at BCM
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: 555T
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: The Passlock II wire colors are yellow, ORANGE / black, and RED / white (not used).
Be careful whose advice you buy, but be patient with those who supply it.2003 Saturn L300 Alarm/Remote Start Wiring - Last Post -- posted image.
sam1544
Posted: October 27, 2005 at 11:32 AM / IP Logged
So, are the PASSLOCK II wires in the ignition harness itself? And are they smaller than the others?
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
