Adding a powered sub in a 2003 F150
wmramse
Posted: December 10, 2002 at 8:25 PM / IP Logged
I just bought a new 2003 F150 with a stock tape deck. I really want to keep a somewhat stock appearance, but I gotta have CDs. I'm looking at dropping in a new stock 6 disk in-dash changer, and I'm curious...what would be the best way to add a powered sub to the stock deck, or is it even possible without upgrading the speakers and putting in an amp?
I want to upgrade the stock speakers later, but for now a powered sub would be enough. If its possible to add in the powered sub, should I put in in-line crossovers for the main speakers?
Any suggestions would be appreciated! Thanks!
NyxBass
Silver - Posts: 226
Posted: December 11, 2002 at 10:04 PM / IP Logged
Unless they really sound like they need it, don't worry about crossing the mains for now, inline's just add distortion unless they are really nice 3-6 order ones. Adding a powered sub would be very easy, just use a high>low level converter to get a signal, or even many self powered subs have high>low level converters in the amp. That should do you very well for in there.
/NyxBass
wmramse
Posted: December 12, 2002 at 7:21 AM / IP Logged
Thanks man. I had thought about that, but I didn't know if that was the best way to do it or what. Should I just split a signal off the front 2 channels to the sub, or would the rear work better?
NyxBass
Silver - Posts: 226
Posted: December 12, 2002 at 3:28 PM / IP Logged
usually it's done off the rear, but only for convenience sake (they're already in the trunk). Whatever is easiest should work just fine.
/NyxBass
