g6 remote start
fatgotti
Copper - Posts: 177
Posted: October 26, 2005 at 3:16 PM / IP Logged
im lost.  i have an omega max e remote start alarm combo in this car.  sometimes it starts sometimes it doesnt. when the car doesnt start the acc wire is powerig up before the car cranks.  when it  cranks it actually doesnt crank the dash lightsi just blink off then on.  im at witts end with this car, any help would be greatly apperciated. thank you
Fatgotti    Yeah my name is John and I am FAT!! YEAH BABY
mo12v
Posted: October 26, 2005 at 3:22 PM / IP Logged
Might check the Plugs on the Unit & Ground .....plus the connections
Strange to be erratic.......I haven't had a bad one yet
MO
fatgotti
Copper - Posts: 177
Posted: October 26, 2005 at 3:26 PM / IP Logged
me either its a great unit just not as simple as some others
fatgotti
Copper - Posts: 177
Posted: October 26, 2005 at 3:28 PM / IP Logged
when i check the heavy guage wires when remote starting it does the same thing when it fires as it does when it doesnt
all connections are firm and even swithed brains.  same results
Moderator - Posts: 12,488
Posted: October 26, 2005 at 3:36 PM / IP Logged
First thing I would look at is the bypass module and making sure that it is properly grounded and powered. Next I would look at the status wire coming from the Omega unit to ensure that your getting a true (-) when remote started. We need to know what bypass module you used as well.
fatgotti
Copper - Posts: 177
Posted: October 26, 2005 at 4:32 PM / IP Logged
using omega pass-4.  ground and power are good i've talked to a few people around here and noone seems to know anything
fatgotti
Copper - Posts: 177
Posted: October 26, 2005 at 4:42 PM / IP Logged
- ignition is good replaced pass-4 unit and its all working now.  i dont understand why it was so eratic but its working now. thank you for the help.  i was just working on a hundred things today and overlooked the obvious.  thanks again
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
