one more svc vs dvc setup thread
meef
Member - Posts: 44
Posted: October 31, 2005 at 1:43 PM / IP Logged
ok, so ive got a 98 Eagle Talon, and just picked up an MTX Thunder 942 amplifier (see specs here), but havent decided what kind of setup i want to do. ive searched and searched, and aside from different wiring configurations, i couldnt really find any advantages/disadvantages of doing four SVC subs vs 2 DVC. id be running each channel of the amp at 2ohms regardless, but im just wondering what kind of setup would be better? space isnt an issue, but i have heard that more subs means more air being pushed...is that statement accurate? i mean it sounds right, but i wanted to get everyones opinions on this before i start dumping more money into this project.   thanks in advance everyone.
-meef
DYohn
Moderator - Posts: 10,741
Posted: October 31, 2005 at 1:48 PM / IP Logged
The difference between 2 subs and 4 subs (assuming the subs are the same type) is approximately 3db.  This is about 1/3 louder.  There will in general be no difference in output between a SVC and a DVC sub of the same type.
suicidecustom
Member - Posts: 25
Posted: October 31, 2005 at 2:58 PM / IP Logged
as soon as you double the number of drivers you gain 3db, witch is the equivilant of doubling your power output. if you can go with 2 dvc drivers then do it, it will be louder than a single svc sub
Sunday, May 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
