Amp rack plexi glass window how to
_Keith_
Member - Posts: 28
Posted: November 02, 2005 at 10:48 PM / IP Logged
Ok I been doing fiberglass and all but my main question is when you guys do a amp rack and do the plexi window how are you holding it in? Are you just covering the wood in whatever then squeezing it in or are you bolting it down? I want it to look clean and not be able to see whats holding it in.
RalphWiggum
Member - Posts: 34
Posted: November 03, 2005 at 12:12 AM / IP Logged
I have used items similar to these...usually the metal mending plates stretched across the corner of the plexi so it cannot be seen.
Amp rack plexi glass window how to - Last Post -- posted image.
jstruckman
Copper - Posts: 465
Posted: November 03, 2005 at 9:31 AM / IP Logged
Most plexi install are screwed down and then have a cover panel over them, usually wrapped in vinyl to make it look clean.
Jazzy
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
