Car sometimes starts, other time fails
Wacboyjulian
Member - Posts: 11
Posted: November 08, 2005 at 11:29 PM / IP Logged
I have a viper 430 or something around those numbers (sorry)
i just have a concern or 2
My car, an automatic 00 Celica GT had an Remote start installed by an MECP (wahtever that means) certified tech
anyways, after having it for a little over then a year, when i hit the remote start button, the car will turn the engine over but sometimes it doesn't start
is it because of crappy fuel? the GT only requires 87 octane but when i've added premium it seems to have more "successful" starts
is there any other way to fix my problem? can i tell my tech to please adjust the ignition process?
its kind of embarrasing when i try to start the car in front of my friends and turns the engine over but won't start, just the electronics stay on after that
If life gives you a lemon, you better give that lemon to me.
redpeppers
Silver - Posts: 483
Posted: November 08, 2005 at 11:47 PM / IP Logged
sounds like a tach problem.....he may have it turned onto voltage sense.....if the tach wire is not hooked up then that would cause it to do that.......i bet that the installer didnt hook the tach up because on that car it is kinda hard to get too.....
Where theres is a wire there's a way.
Wacboyjulian
Member - Posts: 11
Posted: November 09, 2005 at 2:12 AM / IP Logged
so if he connects up the tach then the viper system should automatically adjust the remote start and extend the cranking when neccessary
slammedb5
Copper - Posts: 103
Posted: November 09, 2005 at 2:30 AM / IP Logged
This may sound crazy, but check your hoodpin first. A loose hood pin can cause falsing and faulty remote start operation. Just FYI before you start removing your underdash.
EK Civic
security
no audio
Wacboyjulian
Member - Posts: 11
Posted: November 09, 2005 at 2:37 AM / IP Logged
hoodpin? as in the actual pin that holds down the hood of my car???
im positive that its in working order but i'll check it
regardless even if that is the case, im not gonna handle it. thats why i have an installer
slammedb5
Copper - Posts: 103
Posted: November 09, 2005 at 3:09 AM / IP Logged
hoodpin as in pin switch, under hood, although i'm sure you knew what i was refering to. in any case, if you didn't want my opinion, why did you post? go have your installer adjust your ignition process.
EK Civic
security
no audio
Wacboyjulian
Member - Posts: 11
Posted: November 09, 2005 at 4:13 AM / IP Logged
sorry slammed, i didn't mean to sound ungrateful: thanks for helpin out man
i was just wondering if it was more of a user or installer related fix
pss5075104
Copper - Posts: 144
Posted: November 09, 2005 at 9:44 AM / IP Logged
just connecting the tach. the system will not automaticaly adjust the brain has to be set from voltage to tach, and tach has to fist be learned.
D
MECP First Class Certified Installer.
Nothing is impossable, it's just more expensive.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
