remote start, Acura Integra
Jthoj
Posted: November 25, 2005 at 11:55 PM / IP Logged
I just wanna know how to bypass my clutch switch, so i could remote start on my acura integra.
riceman
Copper - Posts: 109
Posted: November 26, 2005 at 1:01 AM / IP Logged
I just want to warn you that you are gonna get flamed on big time by other members on this forum about safety and the liability. Is this your own car? Are you the only one that drives it? Cars starting in gear are the cars u just let someone else drive. I.E someone drove it, left it in gear and  u RS next mourning and there you go with the liability. Its real easy if you can install the remote start I'm sure you can figure it out. Well good luck.
cntrylvr79
Silver - Posts: 582
Posted: November 26, 2005 at 6:43 PM / IP Logged
As riceman said if you can install the remote start yourself you can figure out the clutch bypass.  It's not hard you need either one or two relays depending on if you have crusie control or not.
Cause I'm So white and nerdy...
First Class Certi-fried installer
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
