Jl audio 10W6v2 vs Diamond Audio D910D2
ryan2100
Member - Posts: 12
Posted: December 01, 2005 at 5:33 PM / IP Logged
I am trying to find out if anyone has any experinece with the Diamond D9 subs.  I am looking to run a D9 10" dual 2 ohm sub in my system.  I have a new JL audio 10W6 Dual 4 ohm, and I am contemplating as to which sub to use.  The Jl would be getting 300W at 2 or 8 ohm if used and the diamond would be getting 600w at 4ohm?.  What sub would sound better under these conditons?
tcss
Silver - Posts: 1,623
Posted: December 01, 2005 at 7:13 PM / IP Logged
How can you get a larger power number at 4 ohms then at 2 ohms? Are you using two differant amps?
There is no such thing as free installation!
Teamrf
Gold - Posts: 1,031
Posted: December 01, 2005 at 8:16 PM / IP Logged
I haven't heard any diamond subs in person but I've done several subs with the W6's and those are some pretty clean subs.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
ryan2100
Member - Posts: 12
Posted: December 01, 2005 at 8:37 PM / IP Logged
the amp that I have is a diamond audio D7152, it is 150x2 at 4ohm, 300x2 at 2ohm and 600x1 at 4ohm,  The amp is not stable bridged at 2 ohm.  The Jl is a dual 4 ohm, so I can only run it at either 300w at 2 ohm from 1 channel or run it at 300w at 8ohm bridged between the 2.  The diamopnd is a dual 2 ohm so i can wire it to 4 ohm and thus get 600w to it.
autotech mobile
Member - Posts: 34
Posted: December 01, 2005 at 8:47 PM / IP Logged
Both subs sound great. My preference is the Diamond, quality is great, sound is tight and strong, and they are capable of playing very loud.
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
