97 Tahoe, Autopage RS-85 alarm/rs
Geeque
Silver - Posts: 310
Posted: December 02, 2005 at 3:48 PM / IP Logged
Try what I said, with the truck running for a while before programming. Also, with the truck running, test the wire your tapping into with a VM on ohms and see if the signal fluctuates when you presson the gas. Try that and let me know.
Gary Kline
MECP Master Technician
Geeque
Silver - Posts: 310
Posted: December 02, 2005 at 3:50 PM / IP Logged
ECM is not in engine compartment, its behind glove to the right. Wire is white.
Gary Kline
LooneyG
Member - Posts: 43
Posted: December 02, 2005 at 3:55 PM / IP Logged
Thank you very much for the tips i will get back to you tomorrow to give you a update on how everything went.
LooneyG
Member - Posts: 43
Posted: December 02, 2005 at 4:23 PM / IP Logged
That was the weird part i checked there and didn't see anything other than the Airbag connections so i looked into the Chilton and they said something about the Coil/ECM deal being the box i tapped into.
kgerry
Platinum - Posts: 3,455
Posted: December 02, 2005 at 5:11 PM / IP Logged
i usually grab it right at the cluster
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
LooneyG
Member - Posts: 43
Posted: December 02, 2005 at 6:00 PM / IP Logged
Here is where i made the Tach connection
97 Tahoe, Autopage RS-85 alarm/rs - Page 2 -- posted image.
Geeque
Silver - Posts: 310
Posted: December 03, 2005 at 8:31 AM / IP Logged
Cluster can be difficult to get to. Sometimes you can grab it at the test plug under the dash. The wire your trying to use does it fluctuate when you depress the gas?
Gary Kline
LooneyG
Member - Posts: 43
Posted: December 03, 2005 at 10:43 AM / IP Logged
Yes
LooneyG
Member - Posts: 43
Posted: December 11, 2005 at 11:47 AM / IP Logged
Is there any way to reset this unit without going into Programming Mode ??? I've tried to get in there and its not working 97 Tahoe, Autopage RS-85 alarm/rs - Page 2 -- posted image.
LooneyG
Member - Posts: 43
Posted: December 11, 2005 at 12:33 PM / IP Logged
As of right now the unit won't do anything i've checked all the fuses and they all look fine i've taken them out and let the unit sit for about 10 Minutes and it still wouldn't respond when i pressed the arm or any other button on the remote any help is appreciated !!!
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
