2005 honda crv, remote start
finnegan
Member - Posts: 9
Posted: December 07, 2005 at 5:29 PM / IP Logged
looking for way to disable factory alarm w/aftermarket  starter ,any ideas?
finnegan
Member - Posts: 9
Posted: December 07, 2005 at 5:30 PM / IP Logged
aslso keysense light is on -used a 555h bypass  unit????
Geeque
Silver - Posts: 310
Posted: December 07, 2005 at 6:17 PM / IP Logged
Use factory remote to disarm only, unlock the doors with factory remote and do not use any more. Also, do not lock doors with the DL switch with the doors open or this will set factory alarm. As long as you don't do these two things you should be ok.
Gary Kline
MECP Master Technician
gus1
Gold - Posts: 1,013
Posted: December 07, 2005 at 6:22 PM / IP Logged
Just did one last night.... fun stuff.
To arm/disarm factory alarm, you need to pull into the door.   Panel is about as much fun as the tilt lever to pull off. White, and a WHITE/ red at the doorlock module in the door (switch assembly).
556HW works well for the key security. Mode 1. You could also use the 555I, as I believe 555H was for older Preludes and the like.
Gus
JWorm
Platinum - Posts: 2,208
Posted: December 08, 2005 at 12:21 AM / IP Logged
There are arm and disarm wires for the factory alarm inside the car. I have called DEI tech support and gotten them. Not surprisingly, they are at the factory alarm plug.
The 555H does not work on that car. The 556H or 555i will.
jacqueslacombe
Copper - Posts: 124
Posted: December 08, 2005 at 2:46 AM / IP Logged
 Well according to astro chart in canada  the alarm system should be under the driver dash near the cluch pedal  you can remote start the car without disarming the system you need to cut the yellow wire using a relais to the alarm module.
cocolaboy
finnegan
Member - Posts: 9
Posted: December 08, 2005 at 10:24 AM / IP Logged
remote start is in but im getting  akeysense light flash the whole time its running unless you start the car with the key and the avs light comes on and wont shut off.......
gus1
Gold - Posts: 1,013
Posted: December 08, 2005 at 4:34 PM / IP Logged
Arm disarm indise the car???? Where would these magical wires be located at?
Gus
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
