2002 Nissan Frontier Remote Starter
redf150
Posted: December 08, 2005 at 7:56 AM / IP Logged
2002 Nissan Frontier Remote Starter - Last Post -- posted image. Does anyone have the wiring directions for a Bulldog Remote Start Model 82 for a 2002 Nissan Frontier XE Automatic 4cyl. I had an aftermarket cruise installed.
Thanks 2002 Nissan Frontier Remote Starter - Last Post -- posted image.
j68rh
Copper - Posts: 147
Posted: December 08, 2005 at 9:00 AM / IP Logged
go to www.bulldogsecurity.com and they have all kinda diagrams
NISSAN
MODEL YEAR(S)
FRONTIER 2002 -2003
KEY T-HARNESS IMMOBILIZER
N/A N/A N/A
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT GREEN (+) IGNITION SWITCH HARNESS
STARTERBLACK / YELLOW (+) See NOTE *1 IGNITION SWITCH HARNESS
STARTER 2GREEN/ YELLOW (+) See NOTE *1IGNITION SWITCH HARNESS
IGNITION 1BLACK/ WHITE (+)IGNITION SWITCH HARNESS
IGNITION 2N/A
IGNITION 3N/A
ACCESSORY /HEATER BLOWER 1RED / YELLOW (+) IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2N/A
KEYSENSEN/A
PARKING LIGHTS ( - )N/A
PARKING LIGHTS ( + )BLUE/RED (+) @ STEERING COLUMN HARNESS
POWER LOCKYELLOW (TYPE B) @ SMART ENTRY MODULE, See NOTE *2
POWER UNLOCKYELLOW/RED (TYPE B) @ SMART ENTRY MODULE, See NOTE *2
LOCK MOTOR WIREBLUE (+) @ SMART ENTRY MODULE, See NOTE *2
DOOR TRIGGERRED / BLACK (-) @ SMART ENTRY MODULE, See NOTE *2
DOMELIGHT SUPERVISIONUSE DOOR TRIGGER
TRUNK RELEASEN/A
SLIDING POWER DOORN/A
HORNLIGHT GREEN/ RED (-) or BROWN (-) @ STEERING COLUMN HANRESS
TACHPINK/BLUE or BLACK @ INSTRUMENT CLUSTER, See NOTE *3
WAIT TO START LIGHTN/A
BRAKEBROWN / RED (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM N/A
ANTI-THEFTN/A
NOTES
NOTE *1 When Installing a REMOTE STARTER, you MUST use BOTH Starter #1 and Starter #2 wires. Both wires must be connected to the STARTER/CRANKING Output wire from the Remote Starter or the vehcile will NOT Remote Start when the Engine is cold.
NOTE *2 THE SMART ENTRY MODULE IS LOCATED TO THE RIGHT OF THE STEERING COLUMN. THESE WIRES WILL ONLY METER WHEN TURNING THE KEY IN EITHER DOOR CYLINDER.
NOTE *3 THIS WIRE IS ALSO AT THE ECM (Electronic Control Module) LOCATED BELOW THE HEATER BOX TO THE RIGHT OF THE GAS PEDAL. THE TACH WIRE IS IN THE TOP ROW, 3RD PIN LEFT OF CENTER.
LINK 1 LINK TEXT 1 LINK 2 LINK TEXT 2
redf150
Posted: January 05, 2006 at 1:01 PM / IP Logged
I've installed the remote it worked as advertised for a while, but now the parking light option does not work
with the remote. The parking lights work on the vehicle side ok, but not through the module.
Wiring is ok.
Any ideas.2002 Nissan Frontier Remote Starter - Last Post -- posted image. 2002 Nissan Frontier Remote Starter - Last Post -- posted image. 2002 Nissan Frontier Remote Starter - Last Post -- posted image. 2002 Nissan Frontier Remote Starter - Last Post -- posted image.
rdlybeck
Copper - Posts: 81
Posted: January 05, 2006 at 6:05 PM / IP Logged
You need a relay for this system to your blue/red parking light wire.  If you havn't installed one do so.  You may have damaged the module if you didn't have a relay hooked up.
Ryan Lybeck
"Wiring diagrams are nice but still double check with DMM"!
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
