4 LED rods to 1 switch
mappu19
Posted: December 13, 2005 at 9:41 PM / IP Logged
Could someone please give me a hand with how to wire the following.
I have installed 4 pre-made LED rods that normally run off the 12v cigarette lighter, but I want to hook all four into a toogle switch in my dash and run power directly from the battery.  Do I need a fuseholder in there somewhere?  And will I need to hook a relay up before or after the toogle switch? Thanks to anyone who can help.
Mitsu Lancer Coupe - Kenwood 6.5 inch splits, 7x10 3 ways - custom 3/4 panel install; Pioneer 12"; Blaupunkt amp.
menace2sobriety
Silver - Posts: 394
Posted: December 14, 2005 at 3:45 AM / IP Logged
check and see if there is a resistor inside the cigarette plug first. i doubt there is but check anyhow. If there is you will need to use the resistor too. every power wire needs to be fused. 5 amp will work for what you are doing, why would you need a relay?  if you use a relay it goes before the switch.  come off the battery and put a fuse close to the power source.
cowboy21
Copper - Posts: 64
Posted: December 15, 2005 at 3:03 AM / IP Logged
one wire from battery to one fuse, one wire from fuse to switch, four wires from switch to led tubes (one wire to each) easy 4 LED rods to 1 switch - Last Post -- posted image.
modest yet effective... ECLIPSE 12", Venom 8"x2, Focal 5 1/2" comp.,Response amps x2 (580WRMS total @ 4Ohms), Pioneer TFT + DVD, good for 148.7dB
mappu19
Posted: December 15, 2005 at 3:28 AM / IP Logged
Yeah, thanks guys.  I've now got the 2 LED's hooked up, but I changed the other two under-dash lights to neons.  The only problem might be that the LEDs run off a 5 amp fuse, and the neons off 10 amp. If it blows the fuse, I'll just install a second switch and fuse holder.  Thanks again, and I'll post a couple of pics as soon as they're finished.
