Arctic Start/Compustar 2W900FMAS Problem
interfire
Member - Posts: 18
Posted: December 20, 2005 at 1:19 PM / IP Logged
I'll be sure to look into that and see what I can find out. If I can fix that problem without this new bypass it'll save me 60 bucks.
I'm not sure where I tapped into power, I'll have to go look at it (I'm an hour away from the car so I'll check it this evening) but the starter/alarm unit I am replacing worked fine with the bypass even when it was armed so hopefully I am just overlooking a wire. But I will look into what you suggested.
I only have one accessory hooked up so I guess I don't need a diode, should I put any on my resistor made bypass to see if that eliminates anything? I'll post back later when I have a chance to look more into it.
Again, thanks for your help.
interfire
Member - Posts: 18
Posted: December 21, 2005 at 3:01 AM / IP Logged
Well it turned out to be my bypass... I should have paid more attention to it I guess but I hooked up the 556L (Which is so much easier... auto programming) and it fired up first try. I left everything half tucked away and I'll try it more tomarrow before finishing up just to make sure everything works 5 times over.
Thanks all you guys for your help and input, it was greatly appreciated.
Page of 4
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
