00 bravada door locks
mo12v
Posted: December 16, 2005 at 8:33 AM / IP Logged
Should show NEGATIVE when you Unlock wth Factory Remote or Turn Key in Driver Door Lock
OEM Alarm DisarmL GREEN (-)AT BCM ON HEATER DUCT OR DRIVER KICK
MO
kgerry
Platinum - Posts: 3,455
Posted: December 16, 2005 at 8:47 AM / IP Logged
WHAT BYPASS MODULE ARE YOU USING?   if you are using a GMBP then they refer to the Class II data wire, not the passlock data wire.....  you have it hooked up wrong.... data for a GMBP is the violet wire at the OBD connector as i mentioned previously....
exactly which bypass did you purchase?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Friday, February 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
