Remote starter, Heater problem
danman16037
Member - Posts: 6
Posted: December 17, 2005 at 5:26 PM / IP Logged
Hi guys great web site!!
I have a 2003 Dodge full size cargo van. I installed a Astra 1000rs remote start system, The high fan setting on the heater dosen't work nor does the compressor run on the max A\C setting while in the remote mode.. I have the accessories and both ignition wires hooked up.It does start but it takes a long time to heat up. I would very much apreciate any advice on what other wiring I need to hook up. Thanks, Dan
KarTuneMan
Platinum - Posts: 7,056
Posted: December 17, 2005 at 6:16 PM / IP Logged
does the fan work on another posistion (like low) while remote started?
danman16037
Member - Posts: 6
Posted: December 17, 2005 at 6:38 PM / IP Logged
yes the low and mediun settings worke fine
chris354
Silver - Posts: 253
Posted: December 17, 2005 at 7:39 PM / IP Logged
According to my notes tgere are 2 acc wires that need to be hooked up if this is a dodge ram van. The wires are blue and orange.
danman16037
Member - Posts: 6
Posted: December 17, 2005 at 8:20 PM / IP Logged
Thanks cris354, the blue wire is hooked up, Ill try adding the orange,
