06 Honda Odyssey remote start
northern
Copper - Posts: 154
Posted: December 19, 2005 at 12:14 PM / IP Logged
Need wiring diagram for remote start. I did a search, all the direct tech's wiring guides have dead links.
Moderator - Posts: 12,488
Posted: December 19, 2005 at 2:49 PM / IP Logged
Links for fine for me. Here's the information:
DIRECTWIRE™ WIRING INFORMATION - HONDA / ODYSSEY / 2006 / Remote Start
[PRINT THIS PAGE]
12volts      white (50A)       +       ignition harness
Starter      BLACK/ white       +       ignition harness
Second Starter      N/A
Ignition      BLACK / YELLOW       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      BLACK/ red       +       ignition harness
Second Accessory      WHITE/ red       +       ignition harness
Keysense      RED / white       -       ign harn or MICU, 30 pin plug, pin 2
Notes: The MICU (Multiplex Integrated Control Unit) is part of the driver side fuse/relay box. It has two plugs on the side edge of the fuse/relay box.
Power Lock      pink/black       -       pass kick or MICU, 30 pin plg, pin20
Notes: Meter this wire while pressing the passenger side door lock switch.
Power Unlock      green       -       pass kick or MICU, 30 pin plg, pin 6
Lock Motor      yellow/black       5wi      driver fuse/relay box, 12 pin plug
Unlock Motor      YELLOW /GREEN       5wi      driver fuse/relay box, 12 pin plug
Parking Lights+      RED / black       +       dri fuse/relay box, rear 17 pin plug
Parking Lights-      RED / black       -       headlight switch in column cover
Hazards      GREEN/ red       +       hazard switch
Turn Signal(L)      RED / blue       +       dri fuse/relay box, rear 17 pin plug
Turn Signal(R)      brown       +       dri fuse/relay box, rear 17 pin plug
Reverse Light      green       +       dr kick or MICU, 14 pin plug, pin 11
Door Trigger      yellow       -       interior light switch on dash
Notes: The individual door trigger wires are at the rear of the driver fuse/relay box in the driver kick. The LF door is green in a 16 pin plug, pin 15. The RF door is lt. GREEN/ red in a 14 pin plug, pin 12. The LR door is GREEN/ YELLOW in a 16 pin plug, pin 14. The RR door is GREEN / WHITE in a 14 pin plug, pin 13. Use all four wires and diode isolate each.
Dome Supervision      BLACK/ red       -       interior light switch on dash
Trunk/Hatch Pin      GREEN/ black or lt. GREEN/ black      -       rear junction box, 13 pin plug
Notes: The rear junction box is in the passenger side quarter panel.
Hood Pin      yellow/red to GREEN/ black       -       pin switch under hood
Trunk/Hatch Release      WHITE/ black and yellow/blue             power tailgate switch on dash
Notes: Use a relay to connect the WHITE/ black and yellow/blue wires to release the power tailgate.
Power Sliding Door      see DirectFax document 1085
Notes: Follow the wiring on DirectFax document 1085 using the following wire colors:
driver side open - WHITE/ blue
driver side close - WHITE/ black
driver side common - GREEN / WHITE
passenger side open - pink
passenger side close - RED / white
passenger side common - lt. green
Factory Alarm Arm      blue/white to WHITE/ blue       -       driver door module in door
Notes: Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm      BLACK/ red to white       -       driver door module in door
Disarm No Unlock      see factory alarm disarm
Tachometer      NOT yellow/black       ac       any fuel injector
Wait to start      N/A
Brake Wire      WHITE/ black       +       brake pedal switch
Parking Brake      GREEN/ orange       -       parking brake switch
Horn Trigger      GREEN/ YELLOW       -       horn switch
Memory Seat 1      blue       -       driver kick or power seat ctrl unit
Notes: The power seat control unit is under the driver seat.
Memory Seat 2      blue / YELLOW       -       driver kick or power seat ctrl unit
Memory Seat 3      N/A       -
northern
Copper - Posts: 154
Posted: December 19, 2005 at 6:28 PM / IP Logged
try posting them again, i think after a few days they go dead. They take me to directed's website, but then it says enter user/password.
Posted: December 19, 2005 at 6:51 PM / IP Logged
&yr=6110&product=Remote%20Start
The link doesn't go dead. It a static link that the information is stored in on their server. Try copying it and pasting this information. I just did it and it worked for me.
mo12v
Posted: December 19, 2005 at 8:57 PM / IP Logged
northern is correct.
DEI has changed their PRINT Links or my computer is also messed up.
Velocity Link:
Correct Link:
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=6110&product=Remote Start
MO
gus1
Gold - Posts: 1,013
Posted: December 20, 2005 at 12:15 AM / IP Logged
And have a good old fashioned aggrivating time getting that tilt handle off so you can get the shroud off....... my least favourite Honda
Gus
thepencil
Gold - Posts: 1,526
Posted: December 20, 2005 at 9:14 AM / IP Logged
30 minute to take it off and 50 minute to get it back on for the first timer. 06 Honda Odyssey remote start -- posted image.
35 minute to take it off and 1 hour to get it back on for the second timer. 06 Honda Odyssey remote start -- posted image.
1 hour to take it off and 2 hours to get it back on for those in a hurry. 06 Honda Odyssey remote start -- posted image.
Unlike you gus1. It's my favourite!
Be careful whose advice you buy, but be patient with those who supply it.06 Honda Odyssey remote start -- posted image.
knauto
Posted: January 21, 2006 at 1:13 AM / IP Logged
Hi i'm have some problem with installations remote stater & alarm on Honda odyssey 2006 i 'm using HOLD3 module by pass control all door lock  & alarm but only problem that when i starter the car with key then remove it i can not lock the door i have to unlock & lock again then it work ??
does any one know how to fix this problem ?
Ken
Chris Luongo
Platinum - Posts: 3,746
Posted: January 21, 2006 at 8:00 PM / IP Logged
If you apply the parking brake pedal hard, there is enough room to get the ignition wires there.
And then you can unsnap the column shroud JUST enough to fish the ring for the bypass module around the key cylinder.
It's still one of my least favorite cars, but that does make it a lot easier.
