1995 chevy Corsica Remote Start
whcollier
Member - Posts: 21
Posted: December 19, 2005 at 2:27 PM / IP Logged
hey ladies and gents... merry Christmas and a Happy New Year... OK check this out.. my mother in law has a 1995 Chevy Corsica 4 door sedan/coupe? anywho I ordered her a remote start with keyless entry for christmas because she has to reeze her butt of just to go out and start her car so it isnt too cold when she gets in it to go anywaher.. we live in Utah and winter has set in and its cold as hell here... anyway if anyone has any wiring/help/suggestions on this specific install I would greatly appreciate your input, the remote start/keyless entry is made by bull dog and is a fairly decent setup..
the model of the remote start/keyless entry setup just says Bulldog Security Deluxe Car starter, and that is all it says on the sams club web site... so please let me know if you have any suggestions or any other pertinant information
thanks
Bill
Teamrf
Gold - Posts: 1,031
Posted: December 19, 2005 at 2:30 PM / IP Logged
That car should be pretty simple to do the installation on. Only thing I reccomend you doing is taking your time, and being careful.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
brhaugen
Copper - Posts: 275
Posted: December 20, 2005 at 1:28 PM / IP Logged
Go To Bulldogsecurity.com they have all the info for installing your Bulldog unit...
thepencil
Gold - Posts: 1,526
Posted: December 20, 2005 at 2:42 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / CORSICA / 1995 / Remote Start
12volts red    +   ignition harness
Starter yellow    +   ignition harness
Second Starter
Ignition pink    +   ignition harness
Second Ignition
Third Ignition
Accessory orange    +   ignition harness
Second Accessory
Keysense
Power Lock lt. blue    +   convenience center
Notes: The convenience center is located to the left of the steering column.
Power Unlock white    +   convenience center
Lock Motor
Unlock Motor
Parking Lights+ brown      headlight switch
Notes: The headlight switch is easily accessed by pulling the gauges. The parking lights are also located low in drivers kick panel.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger      -   convenience center
Notes: Use lt. GREEN/ black for the drivers door, lt. blue for the passenger door, and lt. blue/black for the rear doors. Diode isolate each door trigger.
Dome Supervision white    -   underdash light
Trunk/Hatch Pin black    +   at trunk light
Hood Pin
Trunk/Hatch Release black    +   at release switch
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer pur/wht or white    AC distributor
Notes: The white wire is also found at the rear of the instrument cluster.
Wait to start
Brake Wire white    +   brake pedal switch
Parking Brake
Horn Trigger black    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.1995 chevy Corsica Remote Start - Last Post -- posted image.
