2002 Honda Accord alarm/remote start
northern
Copper - Posts: 154
Posted: December 21, 2005 at 9:09 PM / IP Logged
Vehicle is a 2002 accord SE.
Equipment: as2520 autostart.
HM-t100 for bypass portion.
HODL for door locks/alarm interface
Problem: Door lock unit(hodl)-I hooked everything up, the door switch out I hooked to the green orange wwire on female connector E on the fuse box.
Then I hooked up the HODL violet wire to the brown wire at pin A15 of the K connector behind fuse box.
Something isen't right on this, I don't have any control. My assumption is I have the wrong data connector. Where is the "DATA" connector, also do I have the correct door switch out?
Second problem with bypass kit, hmt100 says to connect to the red wire (data wire) and connect the orange wire of the bypass kit to the blue syncro wire, and then plug the black ground to the BROWN / black ground wire.
Are these wires the ones at the green plug near where you plug the key in?
Will these 2 kits work together on the same data wire?
Craig3708
Copper - Posts: 155
Posted: December 21, 2005 at 9:46 PM / IP Logged
The AS2560 has all the door lock options and security options built in. I don't know why you are using a HODL.
northern
Copper - Posts: 154
Posted: December 21, 2005 at 10:09 PM / IP Logged
We'll I bought it because It said it controlled the trunk/door locks and factory security. It however doesn't control the trunk.
I guess the main problem is the bypass kit, where are the RED / blue and ground wires I need to connect the datawires from.
From my reading, is that you need to have the system disarm the factory alarm before you can trigger the trunk, or the remote start...
Craig3708
Copper - Posts: 155
Posted: December 22, 2005 at 8:36 AM / IP Logged
Honda | | Accord | | 1998 - 2002
Remote Starter Wiring Colors and Notes
FunctionVehicle ColorLocation
Start:BLACK/ WHITE
Ignition #1:BLACK / YELLOWIGNITION SWITCH HARNESS
Ignition #2:YELLOWIGNITION SWITCH HARNESS
Ignition #3:
Accessory:WHITE/ BLACKIGNITION SWITCH HARNESS
Brake Light:WHITE/ BLACKAT SWITCH ABOVE BRAKE PEDAL
Tach Signal:BLUEAT COIL MODULE
Parking Lights:RED / BLACKAT FUSE BLOCK ON DRIVER'S SIDE
Headlights:
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:* This vehicle is equipped with a transponder immobilizer system; See Installation Note #144 - Bypassing Transponder Theft Systems.
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts:WHITEIGNITION SWITCH HARNESS
OEM Alarm Disarm:BLUEINSIDE OF DRIVER'S DOOR
OEM Horn:BLUE/GREEN (-)IN STEERING COLUMN HARNESS
Power Lock:BLACK/ BLUE (-)PASSENGER SIDE FUSE BOX**
Power Unlock:ORANGE (-)PASSENGER SIDE FUSE BOX**
Trunk Release:WHT/RED+# PIN GRAY CONN. ABOVE DRIVER'S KICK
Alarm Input Wire:BLACK/ WHITE (-)4 PIN GREEN CONN. IN PASS FUSE BOX
Notes:** See Note#201 Negative Trigger Door Locks
The remote start unit has a wire that will send a neg pulse out before starting, this must go to the Disarm wire in the drivers door. As you can see from the above chart the door locks are a simple tie in. As for the bypass unit I can't find a installation manual and I dont remember.
Craig
northern
Copper - Posts: 154
Posted: December 22, 2005 at 12:30 PM / IP Logged
Ok, if I do go with out using an alarm module, where is the factory disarm wire on the 02 accord. Is there a way with out using a relay behind the glove box on this model?
Craig3708
Copper - Posts: 155
Posted: December 22, 2005 at 12:34 PM / IP Logged
Craig
northern
Copper - Posts: 154
Posted: December 22, 2005 at 12:54 PM / IP Logged
Any ideas how to disarm the alarm with the press of the trunk button? The alarm goes off when we hit the trunk button.
Craig3708
Copper - Posts: 155
Posted: December 22, 2005 at 1:08 PM / IP Logged
Without reading the Auto-start manual I would be only guessing. You need to find a neg output wire that will send a signal to the disarm wire in the car before opening the trunk. If you unlock the doors first the alarm shouldn't go off. There are a lot of options on these units such as a neg pulse for the horn. For example if there is a option for the horn to blow a second before the trunk opens then you could use this horn wire for a disarm wire. Also without researching this to much you may be able to trigger to dome light to disarm the system.
Craig
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
