2004 town & country, remote start
elvis233
Member - Posts: 16
Posted: December 24, 2005 at 9:50 AM / IP Logged
im trying to install a remoter starter in my mothers 2004 chrysler town & country for a chritmas surprise.. the wire diagram i have says a 180 ohm resistor is needed on the starter wire & 2000 ohm resistor on the parking lights.. i went to radioshack to get them but they didn't have the exact ohms needed and they came in different tolerences & amps... my questions are !!
1)what tolerence & amp resistors do i need
2)could mutlible resistors be used inline to get the correct ohms (1000 ohm + 1000 ohm= 2000 ohms)
3)can they be purchased at radio shack
ps.. i have another wire diagram and it doesn't say anything about using resistors.. are the resistors even needed
soundzplus
Copper - Posts: 71
Posted: December 24, 2005 at 10:21 AM / IP Logged
Answer - yes they can .. need to wire in series to add value together
Answer - Yes - they do carry em
12volts lt. blue/red (10A)  +  ignition harness
Starter yellow  +  ignition harness
Second Starter PURPLE / brown  -  ignition harness
Notes: The second starter wire is negative trigger thru a 180 ohm resistor. MUST use a relay. Refer to DirectFax document 1083 for wiring information.
Ignition pink/white  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory not required for remote start
Second Accessory N/A
Keysense N/A
Power Lock PURPLE / dk. green  -  BCM, white plug, pin 21
Notes: Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Can also use Directed 456L interface modules.
Power Unlock same as power lock wire
Lock Motor tan/white  5wi BCM, green plug, pin 10
Notes: The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Unlock Motor tan/lt. green  5wi BCM, green plug, pin 28
Parking Lights+ WHITE/ brn (L), WHITE/ org (R)  +  driver kick, harness to rear
Parking Lights- WHITE/ brown  -  switch or BCM, black plug, pin 18
Notes: The parking lights are negative trigger thru a 2.1K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. See DirectFax document 1082 for wiring information.
Hazards WHITE/ dk. blue  -  switch or BCM, black plug, pin 1
Turn Signal(L) wht/lt blu (F), wht/dk grn (R) +  BCM, green plug, pins 1, 2
Turn Signal(R) WHITE/ tan (F), WHITE/ brown (R) +  BCM, green plug, pins 3, 4
Reverse Light WHITE/ lt. green  +  BCM, green plug, pin 9
Door Trigger see notes  -  BCM, white plug
Notes: The driver door trigger is purple in pin 6, the passenger door is PURPLE / white in pin 7, the left sliding door is PURPLE / gray in pin 8, and the right sliding door is purple / YELLOW in pin 5. Use all four wires and diode isolate each. Also have to diode isolate from the BCM. Refer to DirectFax document 1076 for wiring information.
Dome Supervision yellow/brown or yellow/white  +  BCM, white plug, pin 33
Trunk/Hatch Pin PURPLE / orange  -  BCM, white plug, pin 29
Notes: A diode must be placed inline on this wire to avoid problems with the dome lights and parking lights.
Hood Pin PURPLE / lt. blue (export model) -  BCM, white plug, pin 30
Trunk/Hatch Release PURPLE / tan  -  BCM, green plug, pin 6
Notes: Hatch release is negative trigger thru a 1.69K ohm resistor. MUST use a relay.
Power Sliding Door PURPLE / dk. blue  -  BCM, white plug, pin 1
Notes: Left power sliding door is negative trigger thru a 1.5K ohm resistor. Right power sliding door is negative trigger thru a 2.7K ohm resistor. MUST use relays.
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Sentry Key
Tachometer NOT BROWN / white  ac  ign coil pack or any fuel injector
Wait to start N/A
Brake Wire WHITE/ tan  +  brake pedal switch
Parking Brake dk. GREEN / WHITE  -  parking brake switch
Horn Trigger dk. GREEN/ purple  -  steering column
Memory Seat 1 PURPLE / brown  -  BCM, green plug, pin 24
Notes: Memory seat 1 is negative trigger thru a 6.8K ohm resistor. Memory seat 2 is negative trigger thru a 2.1K ohm resistor. MUST use relays.
Memory Seat 2 same as memory seat 1 wire  -
Memory Seat 3 N/A  -
2004 town & country, remote start -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Sentry Key
Part #: 556CW
Alternate Part1 #: 556UW
Alternate Part2 #: 555U
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: Standard on all models.
Door Lock Interface
Required:
Yes
Type:
Multiplex
Part #: 456LW
Notes:
Soundz Plus, Inc
Complete Custom Car Audio
Warrenville, IL
elvis233
Member - Posts: 16
Posted: December 24, 2005 at 10:56 AM / IP Logged
do you know what tolerence & watt resistors i should use
ps. thanks for the help
soundzplus
Copper - Posts: 71
Posted: December 24, 2005 at 10:58 AM / IP Logged
standard 1 watt 5% - are fine ..
Soundz Plus, Inc
Warrenville, IL
elvis233
Member - Posts: 16
Posted: December 24, 2005 at 1:00 PM / IP Logged
thanks.. for all your help
Saturday, May 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
