Method of tapping into a wire
Mr_Kite
Copper - Posts: 70
Posted: December 28, 2005 at 9:57 PM / IP Logged
Im interested to read about how you strip the middle of a wire without breaking it.
On my last install I used a stripper to make two cuts and then with a razor, by hand, I sliced in between them. This inevitably led to cutting a few wires, and was very hard on my fingers.
There should be a tool that removes a piece of insulation in the middle of a wire.
Thx for your advice!
gamedemon
Posted: December 28, 2005 at 9:59 PM / IP Logged
its a little dif than your idea but walmart and other autoparts stores sell a connector that just connects on the existing wire and lets you splice of off it.
chris354
Silver - Posts: 253
Posted: December 28, 2005 at 10:05 PM / IP Logged
Iwould not use the ttap type connectors not reliable. I always strip the wire like you the poke the wires through the middle twist and solder.
dualsport
Silver - Posts: 983
Posted: December 29, 2005 at 12:56 AM / IP Logged
shawzie
Member - Posts: 30
Posted: December 29, 2005 at 1:15 AM / IP Logged
is there anything wrong with cutting the wire in half and then twisting the 3 ends togeter and then crimping them?
shawzie
Member - Posts: 30
Posted: December 29, 2005 at 1:17 AM / IP Logged
What kind of connector do you use to tap into the wire doing it that way? any pictures?
dualsport
Silver - Posts: 983
Posted: December 29, 2005 at 1:26 AM / IP Logged
Problem with cutting the wire in half is that you may be disturbing the integrity of the original wiring harness, and you may not have enough slack in the wire to pull the two ends back together with enough overlap to reconnect them properly-
shawzie
Member - Posts: 30
Posted: December 29, 2005 at 1:34 AM / IP Logged
so what can I use without having to solder?
Falcon 1
Copper - Posts: 130
Posted: December 29, 2005 at 8:42 AM / IP Logged
Shawzie you should take the time and solder all connections.
Do it right the first time, only a doctor can bury his mistakes.
Mr_Kite
Copper - Posts: 70
Posted: December 29, 2005 at 11:55 AM / IP Logged
Thx for the replys.
I read dualsport's link... so basically i use automatic strippers that I would normally use on the tip, and use them to squish the insulation to one side?
