Impulse 990 alarm won't work
vinh766
Copper - Posts: 70
Posted: May 10, 2002 at 11:44 AM / IP Logged
hi, i just purchased an impulse 990 off ebay and the guy didn't send instructions. he tried to sell me his instructions for 6 bucks, so i bought it. i have installed everything but nothing seems to happen. im pretty sure i have wired everything up correctely. i have a 1998 honda civic ex 2 door. i know there's power running to it, but nothing seems to happen when i press the remote except for a little clicking sound from the system. can you please help me w/ my wiring or would you know the contact number for the company or to somehow activiate the remote? thank you. i am a big fan of ur site.
Vinh766
Moderator - Posts: 12,488
Posted: May 10, 2002 at 12:06 PM / IP Logged
Make sure that you have your remote control programmed properly . Make sure that your ignition wire is connected to the proper ignition wire on the Honda otherwise the unit will not work.
Mexbaja
Member - Posts: 29
Posted: May 10, 2002 at 9:15 PM / IP Logged
Hi
I had that problem with Impulse Res-R I had to program the remote control this way (I hope this will help u)
1 turn the ignition to the "ON" position
2 Press and hold the valet switch until the system honks or flashes (to indicate ready to learn status
3 Press button #1 of the new transmitter once (the system will honk or flash to indicate learned remote
when done turn ignition off  and try to use you remote
sERgIO
Thinkster
Copper - Posts: 94
Posted: May 12, 2002 at 12:05 AM / IP Logged
Sorry to "Bash",  but I think this should be a lesson to people to not buy this Brand of Alarm or remote starter.   In my opinion, they are junk and nothing but a hassle.   There are so many other reputable brands out there that it's not always the best idea to save a few bucks.
spanoman2000
Posted: December 28, 2002 at 10:21 PM / IP Logged
ijust bought an impulse 990 and need to install to a 1994 ford f-150. could use a wiring diagram and instructions if possable. thanks
Posted: December 28, 2002 at 10:43 PM / IP Logged
spanoman2000.....I replied to your post already on another forum.
