2001 kia sportage limited wiring
shott8283
Copper - Posts: 112
Posted: January 01, 2006 at 8:08 PM / IP Logged
man... ive been wrestling with this kia for a week.. every wire color description that ive pulled off the net.. is not even CLOSE to the colors im seeing when i got it all opened up.  its a 2001 kia sportage limited.. and the closest one i can get .. still a few wires off.. is a 2005 wire color description.  for the remote start ive had to shoot the wires myself and find the right ones..and knowing for a fact that all the descriptions ive gotten are wrong..but pointed me to the right direction...   now i got a tach lock out.. and the suggested wire color for the tach at the diagnostic connector in the engine bay (yellow/white) is reading a steady 12 volts when you turn the key on and to start and acc..  i have NO idea..  even the key sense wire isnt right... it says its  a ltGREEN/ black  or green wire that is 12v when the key is insterted and will disarm the factory alarm  during RS...the wire is actually like a 16ga  or 18 ga wire .. black and red ones goin to the front of the key cylinder and when you inster the key the black wire is energized... so.. any ideas why all the resources i have come in contact with are not even close to what im seeing on the truck... and yes ive checked the vin and it is a 2001 kia sportage...
Mharvey
Copper - Posts: 76
Posted: January 01, 2006 at 8:14 PM / IP Logged
try this may help not sure
SECURITY
 Battery  BROWN AND ORANGE  (+)  PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PINS 12/33 OF 40 PIN PLUG
 Ignition 1  YELLOW  (+)  PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 35 OF 40 PIN PLUG
 Starter 1  BLUE  (+)  PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 15 OF 40 PIN PLUG
 All Door Trigger  BLACK/ WHITE  (-)  AT PLUG TOP OF FUSEBOX
 Domelight Super  BLUE
 LF Latch  RED  (-)  BECU PIN 14 OF A 16 PIN PLUG
 RF Latch  RED  (-)  BECU PIN 23 OF A 28 PIN PLUG
 LR Latch  GREEN  (-)  BECU PIN 11 OF A 28 PIN PLUG
 RR Latch  BLUE  (-)  BECU PIN 16 OF A 16 PIN PLUG
 Trunk Trigger  RED  (-)  BECU PIN 11 OF A 16 PIN PLUG
 Hood Trigger  WHITE/ BLUE  (-)  HOOD PIN SWITCH UNDER HOOD
 Alarm Disarm  ARMS WITH LOCKS
 Alarm Arm  DISARMS WITH UNLOCK
 Parking Lights  GREEN  (+)  AT THE BACK OF PARKING LIGHT UNDER HOOD
REMOTE START
 Ignition 2  LIGHT BLUE  (+)  PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN34 OF 40 PIN PLUG
 Accessory 1  GREEN  (+)  PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 11 OF 40PIN PLUG
 Starter 2  LIGHT BLUE  (+)  PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 17 OF 40 PIN PLUG
 Anti-Theft Type  UNIVERSAL TRANSPONDER
 Anti-Theft Descript  THE KEY SENDS A RF SIGNAL TO THE BCM THROUGH A ANTENNA AROUND THE KEY CYLINDER
 Key Sense  BLUE/WHITE  (-)  IGNITION SWITCH HARNESS
 Neutral Safety  GREEN / WHITE  (-)  AT GEAR SELECTOR SWITCH
 Tachometer  WHITE  (AC)  PIN 9 AT THE DATA CONNECTOR
 Speed Sense  PURPLE  (AC)  ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 14 OF A 26 PIN PLUG
 Brake Lights  RED / BLACK  (+)  BRAKE PEDAL
 Reverse Lights  RED  (+)  ECU PIN13
 Horn  YELLOW  (-)  STEERING COLUMN HARNESS
DOOR LOCK/WINDOWS
Power Unlock  LIGHT GREEN  (-)  POWER MASTER SWITCH IN DRIVERS DOOR
 PowerLock  PINK  (-)  POWER MASTER SWITCH IN DRIVERS DOOR
 Driver Mtr Unlock  RED  (REV)  ECU IN DRIVERS DOOR
 Driver Mtr Lock  GREEN  (REV)  ECU IN DRIVERS DOOR
 Pas Mtr Unlock  RED  (REV)  ECU IN PASSENGER DOOR
 LF Window Up  RED / YELLOW  (REV)  DRIVERS DOOR SWITCH
 LF Window Dn  RED / BLUE  (REV)  DRIVERS DOOR SWITCH
 RF Window Up  BLUE / YELLOW  (REV)  DRIVER KICK PANEL
 RF Window Dn  BLUE  (REV)  DRIVER KICK PANEL
CONVENIENCE
Headlights-Lo  BLUE/RED  (-)  IGNITION SWITCH HARNESS
 Wipers-Lo  BLUE / YELLOW  (-)  IGNITION SWITCH HARNESS
 Trnk Release  LIGHT GREEN  (-)  BECU PIN 13
shott8283
Copper - Posts: 112
Posted: January 01, 2006 at 8:17 PM / IP Logged
i kept lookin around... and beleive it or not... the wiring is closest or almost exact to the rios and spectras colors then it is to the sportages.... damn i hate kia
shott8283
Copper - Posts: 112
Posted: January 01, 2006 at 10:46 PM / IP Logged
the above diagram isnt even close...   these are the colors i got.. working off memory...written down but the paper is downstairs in the truck
red  12v constant
black 12v constant
BLACK / YELLOW starter
white 12v on 0v start
WHITE/ blue 12v on start
green 12v acc on 0v start
no other color description ive found so far co-insides with what im seeing.... unless its for a kia sephia rio or spectra   not a sportage...  this truck is making me feel like i just started installs and have never touched 12volts before... i wanna cry
shott8283
Copper - Posts: 112
Posted: January 01, 2006 at 11:40 PM / IP Logged
btt
shott8283
Copper - Posts: 112
Posted: January 02, 2006 at 2:40 AM / IP Logged
bump.. help
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
