CHDL1B Any complaints?
natsys
Copper - Posts: 87
Posted: January 06, 2006 at 5:50 PM / IP Logged
I'm going to do a 2005 Dodge Caravan R/S and alarm and it seems like a PITA to hook up multiple relays for lock/unlock, 2nd starter, etc.
Bypasskit.com says this module will lock and unlock, provide inputs to horn, parking lights, second starter, AND door status inputs. Sounds too good to be true--and you know what that usually means.
A search of this forum turned up some 2004 posts that would make me run from this product. Has anybody had any experience that would indicate its improved since then? This is the "B" version so maybe they worked out the kinks. Any experience with this--good or bad--would be appreciated.
hgshoemaker
Posted: January 06, 2006 at 6:02 PM / IP Logged
I tried it on an 05 Grand Caravan, it did work but.... every time the customer got in or out of the vehicle the horn honked several times (no you can't turn off the horn feature).
Traced it back to static electricity from the seats. Moved the power and ground to a different source and still had the problem. After 5 hours of moving and filtering sources, I gave up and installed relays and resistors and sent the customer on their way and no trouble since.
tintman97
Copper - Posts: 113
Posted: January 06, 2006 at 6:35 PM / IP Logged
ive used a chdl6-pk2  works awsome for the sentry key systems no sweet spot in the box to find.  Easy to set up  may need to add a relay for lock to work.
Snapper
sparkie
Platinum - Posts: 2,061
Posted: January 07, 2006 at 10:57 AM / IP Logged
The CHDL1BPK module does everything it says, but you need the latest version of it. I think it has to have a "B" in the version number. If not it usually has the horn honk problem. I heard that it happens because of a voltage spike on the data line on older versions. If you don't mind all the relays and resistors that method works flawlessly, but isn't as neat. You will still have to use a module and or key/module to bypass the transponder circuit.
sparky
jacqueslacombe
Copper - Posts: 124
Posted: January 08, 2006 at 4:38 AM / IP Logged
Well  For the2005 van  there is other module that will do the job perfectly  just lock around...
cocolaboy
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
